Eleictrices i have just fitted a cellin light i have wired it right but when i turn the electric back on the fuse box were it says lights blows and trips off when i swicth on can you help me michelle
  • 196 Answers
You have wired it wrong.
Take all the connections apart and start over. Especially look for bare wires outside the connectors.
This is especially dangerous, so you may be better off getting some help.
Posted on Nov 29, 2007
My running lights dont work. keeps blowing fuses
I would take out the bulb and make sure the bulb and terminals are clean on both sides of the vehicle, then make sure you have the right fuse fitted and we'll cleaned contact ps after that get some one with a multimetre to check the electrics with that colin
Jun 10, 2017 | Cars & Trucks
Why does the fuse for my tail lights keep blowing?
It sounds as though you have a loose wiring connection somewhere.
Check your wiring in the area of both tail lights/brake lights. You're looking for corroded, loose or broken wires - and particularly a corroded/broken earth wire. Check the connectors where the wires fit together, too.
If your brake lights are built into the rear tailgate check where the wiring goes through the bodywork and into the tailgate via small holes. The wires may actually pass through rubber grommets/plugs.
Over time - in a tailgate - the wires flex and become brittle with the constant opening/closing and can break. Other than that, check the wiring in the rear light clusters
Feb 20, 2016 | Cars & Trucks
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 04, 2013 | Cars & Trucks
2002 dodge ram 1500 brake and parking lots went out
Both. If the running lights ( marker, tail, clearence, or parking) and brake lights are out since the rain, a tail light assembly is broken and filling with water enough to create a short to ground. If there's no broken lens, whitch normally only blows the bulb. Then, the problem lyes in the trailer light harness. the brown wire (tail) & green wire (left turn/brake or yellow wire (right turn/brake) must be bare exsposed that shorts to ground when wet. all the trailer wires could be smashed together damaged the plastic coating on them. no problem till water shorts to ground. The white wire is the ground wire make its not able to touch the other 3 wires or bare & wet. Tape wires seperate then replace tail/mkr fuse and brake fuse. That should do it.
Jan 30, 2013 | 2001 Dodge Ram 1500 Truck 2WD
1989 chrysler new yorker dash and dome lights and fuse problems
You have a direct short. Take the bulb out of dome light, inspect the socket. Try putting fuse back in while bulb is out. If the fuse blows again, Id say it's in the wiring from the fuse box to the the switch. If the dome light fuse also covers other electrical things, such as lighter, check the socket at all points. You mentioned that other fuses were replaced as well? Which ones, and why did they blow? Sometimes it could be moisture entering your fuse box, or condensation near the computer, but is sounds more like a short. Could be as minor a a bad ground wire, or a chafed wire. While you are putting the fuse back in, it will help to keep your eyes looking around the fuse box for sparks as soon as the fuse goes in. You should also listen for that electrical snap. If this doesn't help, I'd suggest taking head panel down and follow and inspect the wires from dome down to the switch. Then from switch [ which could also be the cause ] to fuse box. look for hot spots, arcs, and bare spots. I hope this helps you out. keep me informed
Jan 05, 2013 | 1989 Chrysler New Yorker
I have a 2000 Volkswagen , my right turn signal light gave out and the light on my dash board (for the right signal as well)
You have a short close to the ends. Chech light fitting, connections to light fittings and sockets at fuse box.either at the light unit or in the wiring
Nov 21, 2012 | Volkswagen Jetta Cars & Trucks
I have an S-10 All my lights work except running lights in the rear ive checked the fuse box and everytime i replace the fuse it blows.
There is a short to ground somewhere in the wiring harness, or at the socket causing the fuse to blow.
To repair, the wiring will have to be traced front to back and insulation restored using electrical tape or shrink tubing.
Dec 19, 2010 | 1988 Chevrolet S-10
Need fuse list for 2001 ford f350 trailer lights not working
In the fuse box under the hood, fuse in position 20 is a 7.5amp fuse for the trailer left turn circuit, fuse in position 22 is a 7.5 amp fuse for the right turn circuit, if the fuses are good and you have power at them it is going to be wiring, at the back of the truck close to the driver side at the bumper is a gray connector that will take factory wiring to you trailer wiring the yellow wire is left turn/brake light, the green wire is right turn/brake light, and the brown is tail lights, and the orange wire is 12volt feed for if there is a battery on the trailer that needs to be kept charged for break away safty brakes.
Sep 18, 2009 | 2001 Ford F350 Super Duty SuperCab
Fuse for trailer right turn signal and brake blows intermittently
abad ground on that tail light unit could affect current load when turn and stop are used simultaneously. Although one side only is affected make sure of good grnd between trailer and tow vehicle. focust on the tail light unit in question. Replace the bulb. though rare, bulbs have been known to be the problem. If the bulb is breaking filiments ck the filiment orientation. filiments last longer in vertical orientation, where horizontal permits vibration to break the heated filiment when brake is applied.. good luck and let me know if This helped or not.
Apr 26, 2009 | 2003 Chevrolet Silverado 2500HD
LG Dyer blows 30amp fuse frequently
Hello davidkado,
There is a high probability that when you replaced your fuse box to circuit breakers that the wiring at the fuse box was retightened. If your dryer had been operating Ok for the better part of a year and then you started to blow fuses on a regular basis.. chances are the wiring coming from the fuse box tap was becoming loose from thermal expansion and contraction and that by changing to a breaker system.. your wiring was cut and reterminated to fit the breaker tap. I suspect you won't be having any additional problems...
Regards,
Rick
Jan 02, 2009 | LG DLE2514 Electric Dryer
Computers & Internet Logo
51 people viewed this question
Alun Cox
David Payne
David Payne
