Question about Motorola Mobility L6 Cellular Phone
Phone keypad keeps freezing and dialing random numbers
I'm hoping someone can help. I have had my phone about 9 months and a couple of weeks ago some water was spilt on it. It started freezing and what ever button I pressed the number 8 would come on screen and it would dial 2425. I could start typing a message but then other letters would appear on screen and it would only let me delete a few and then would freeze. I dried out my phone and although the little dot is now red - I THINK that means that the water has damaged it in some way but am not sure as never noticed the dot before - it has worked fine ever since.
But last night, for no reason, the phone starting acting up and doing all the same things it did before and the only way to stop it was to remove the battery!
Please, can anyone help me!
  • Jordibox Nov 28, 2007
    When you say clean the keypad circut do you mean remove the front case?
  • 456 Answers
Remove the battry and open the fon and put it under sunlight and clean the key ped circuit with the earaser
Posted on Nov 28, 2007
  • Zaid Anarwala
    Zaid Anarwala Nov 29, 2007
    es remove the front case and open the circuit and thats the way
SOURCE:
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
My iphone cracked about a few months ago and a few days ago i spilt water into the crack. It started with my ringtone not working and then my phone completely shut off. I tried restoring it on itunes but...
No, it's not the end but you will most likely need to take it in to a Authorized Repair Center so they can repair the broken, cracked screen and any internal damage since obviously water or moisture getting inside is an issue.
Jun 09, 2010 | Apple iPhone Smartphone
Particular areas on my Blackberry Storm 9350 touchscreen do not respond to touch (cannot highlight or press). Also, every couple of days, the entire touchscreen will not respond and i have to 'cold boot'...
Hi, The screen of a BlackBerry Storm smartphone appears to be easily scratched or has air bubbles.So the BlackBerry Storm smartphone does not respond consistently to finger touches or slides.
This issue could be because one of the following reasons:
1) The clear plastic screen overlay that is placed on the BlackBerry Storm smartphone during the manufacturing process to protect the screen during shipping has not been removed.
2) A purchased plastic screen protector has been placed onto the BlackBerry Storm smartphone.
Still if you are facing the issue then please visit the blackberry service center or contact your service provider if it is under warrenty. I hope this information will be helpful to you
Nov 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Crcked screen
dude thats it mate game over
Oct 13, 2009 | Samsung SGH-A877 Impression Cell Phone
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Keeps freezing and rebooting
Most likely this is a memory issue.  Go in to your options and advanced settings to check for available memory. Remove programs you do not use.  I am posting a link below that will help you free up memory.
http://crackberry.com/blackberry-101-how-free-memory-your-blackberry-smartphone
Hope this helps.
Apr 21, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
Computer wont start-up
If I get you right, after you plug the xternal drive to transfer some file, the system didn't come up. Right?
Well, let me assume yes. If that is the case, I will advise you to boot the system from an external disk and use it to scan the local hard disk for virus. After that, remove the x-hard disk and try to boot the system. If it doesn't work, then transfer all the files to the xternal hard disk and format the local hard disk for new use. Best of luck.
Dec 14, 2008 | HP Compaq Presario V2000 Notebook
9 red blinks
Can you verify that its 9 blinks? There is no error code in that set for 9. also please verify that its a kdsr50xbr1
Thanks
Tim
Jun 29, 2008 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 9 red blinks
Isn't that the idicator telling you that its time to change the dlp lamp?
Jun 28, 2008 | Sony KDS-R50XBR1 50" HDTV
Motorola Mobility L6 Cellular Phone Logo
99 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
