1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe Car Radio Ground Wire = Black Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe Car Radio Dimmer Wire = Light Blue w/ Red Stripe Car Radio Illumination Wire = Orange w/ Black Stripe ?? Don't know ?? Red Wire (No power to wire Constant or Accessory) Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front: White w/ Green Stripe (+) Brown (no stripe) (-)
Right Rear: Purple w/ White Stripe (+) Light Blue (no stripe) (-)
Left Front: Light Green (no stripe) (+) White w/ Orange Stripe (-)
Left Rear: Light Blue w/ Black Stripe (+) Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front: White w/ Green Stripe (+) Green w/ Orange Stripe (-)
Right Rear: Orange w/ Red Stripe (+) Black w/ White Stripe (-)
Left Front: Orange w/ Green Stripe (+) Blue w/ White Stripe (-)
Left Rear: Red w/ Green Stripe (+) Red w/ Blue Stripe (-)
Please rate the answer you received for your question if you feel it solved your problem. Thank you.Please rate the answer you received for your question if you feel it solved your problem. Thank you.
You can't post conmments that contain an email address.
Hi there: Check this on 2004 Ford Explorer Sport Trac Audio Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Light Green Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Power Antenna Trigger Wire: N/A Car Stereo Amp Turn-On Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Tweeter Size: N/A Car Audio Front Tweeter Depth: N/A Car Audio Front Tweeter Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): Dark Green/Orange Right Front Speaker Negative Wire (-): White/Light Green Car Audio Front Speakers Size: 6" x 8" Speakers Car Audio Front Speakers Depth: 2 1/2" Car Audio Front Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink Car Audio Rear Speakers Size: 6" x 8" Speakers Car Audio Rear Speakers Depth: 3" Car Audio Rear Speakers Location: N/A Car Subwoofer Speaker Size: 8" Subwoofer Car Subwoofer Speaker Depth: 4" Car Subwoofer Speaker Location: N/A Car Subwoofer Speaker Positive Wire (+): N/A Car Subwoofer Speaker Negative Wire (-): N/A
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
1995 Ford Explorer Car Stereo Wiring Diagram Car Radio Constant 12v+ Wire: Green/Violet Car Radio Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: Orange/Blue Car Stereo Amp Trigger Wire: Blue (If Equipped) Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
For 1999 Ford Explorer Car Stereo Radio Wiring Diagram check this...
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Blue
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5 x 7
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5 x 7
Rear Speakers Location: Rear Door
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Unfortunately all the photos I have are black and white. The method I use is to look at the speakers themselves and get the colors from the speakers. This has the added advantage of giving you the ability to make sure you have them hooked up in the correct order.
Constant 12v+ Wire: Green/Violet Switched 12v+ Wire: Yellow/Black
Ground Wire: Black/Light Green Illumination Wire: Light Blue/Red Antenna Trigger: Orange/Blue Amp Trigger Wire: Blue (If Equipped) Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
For 1995 Ford Explorer Car Stereo check this Wiring Diagram...
and there should be a diagram on the back of the kenwood deck which would explain the deck side. if not your main power should be yellow = Constant 12V for clock Red = Ignition 12V switch turn on the deck Black = Ground blue purple green white= for speakers
solid color = to positive on speakers color with black stripe = negative on speakers
I would solder and heatshrink all connections Good luck
here is wire color diagram. 1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Red or Black Car Radio Illumination Wire: Orange/Black Car Stereo Dimmer Wire: Light Blue/Red Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Blue Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Pink/Light Green Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Pink/Light Green Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red
