Question about Tascam 2488 Portastudio Multitrack Recorder System
Altering the tempo of a song after recoding
Can you tell me whether the 2488HDCD MK11 is able to speed up (slightly at least) a finished song before burning it to CD?
Thanks John.
    Novelist:
  • 189 Answers
Not as far as I'm aware.
Posted on Jan 03, 2008
SOURCE:
LED failed
You can replace it. There are some types of LEDs: 3cm and 5cm. You should first identfy the K (catod) and the A (anode) to make a correct replacement. The K is marked with a slight cut. Dessolder the bad one from the board and replace and solder the new one.
Jun 18, 2012 | Music
SEtting tempo on metronome Zoom R24
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Jun 01, 2012 | Samson Technology Zoom R24 Multitrack SD...
The Simmons SD5K keeps spontaneously playing songs, even when all I want to do is play my own stuff with the metronome! I turn on the metronome, set the speed, hit the pads a few times, and the music...
Press the "click" button and then set the tempo you want, press the "click" button again this will stop the metronimoe but is also sets the tempo in memory. The next time you press the "click" button it will be ready to go.
Anytime you press the tempo + or - it thinks you are trying to use the "Tap Tempo Function".
Jun 07, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
FM RADIO SONGS NOT RECODING
Are you asking me about Musics ID?
So for your kind information it is not for FM recording , it is to identify the song. So it record the song for certain second only to identify the song
Sep 12, 2010 | Motorola Mobility MOTO ZN200 Cell Phone
Question on the start /stop feature and saving tempo information
As I read the manual, the tempo is saved with the SONG.
Starting and stopping rhythm SHOULD always start at the begining of the song. This is on page 20 of your manual. The manual is available online if you don't have one.
Jun 12, 2009 | Alesis Sr 16 Stereo Drum Machine
Change tempo on existing song
No, sorry there isn't any way to speed up or slow down a track with the DP-02. You'd have to export the track to a program on a pc which will allow you to do this whether it is a program which allows you to chnage the tempo and adjusts the pitch for you, or something that will allow you to slice the track or convert to midi and then adust the tempo there.
Jan 19, 2009 | Tascam DP01 All-In-One Recording Package...
The tempo indicated on the alesis sr16 is inaccurate
how can i change the tempo on song compose, for example step 01 tempo 60 and step 02 tempo 120??
Thanks.
Jan 16, 2009 | Alesis Sr 16 Stereo Drum Machine
1992 Ford Tempo 2.3 Ignition Timing
#1 tdc it is 10 degrees BTDC you must remove the shorting plug at the dist before setting
Nov 21, 2008 | 1992 Ford Tempo
Tascam 2488 Portastudio Multitrack Recorder System Logo
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
