Question about Adobe Photoshop 7.0 for PC
Active x controls
Whenever i try to download from the net a goldenbar appears on the top of the page (your security settings dont allow active x controls)how to get rid of this
    Sergeant:
  • 264 Answers
I will give you a small step that you may try.
Open the Internet Explorer - On the top Click on the tab "Tools"-Under the dropdown click the last option "Internet options"
In this window you will find a tab on the top as "Security"
On the bottom left you will see a slider bar - Pull it down to "LOW"
****If you do not see the slider bad, click on the option "Default" and you will get it.
Click Apply and Click OK. Restart the computer and try again.
Note : This steps lowers your security and allows all the active X on the computer. Most of the spywares also use the medium as Active X, so please calculate the risk before you try the step.
I hope this should resolve the issue you are facing.
Sammy
Posted on Nov 28, 2007
SOURCE:
Will Not Download
What browser are you using?
May 10, 2013 | Acer Computers & Internet
How can active my system?
In some cases, say when you're building and testing a webpage locally (Local Machine Zone), you may still see the Information Bar when the web page executes any script, initiates a Pop-up windows, or a download. For testing purposes, one needs to follow any of these workarounds:
  • Rename the .HTM file to .HTA (Example.. Index.HTM to Index.HTA and test the file locally). HTA files have more privileges than the HTM files, can run active content on Local Machine by default.
    -or-
  • add the Mark Of The Web code such as <!-- saved from url=(0023)http://www.contoso.com/ --> to a Web page, where the (0023) value is the string length of your URL that follows it and Contoso is the name of your Web site.
The above is an extract from Local Machine Zone Lockdown - Developer Implications. See page for more information about the two workarounds above.
To totally disable the Local Machine Zone restriction (for running Active Content) (not recommended, though) for valid reasons, read below:
To allow any Web site to run scripts and ActiveX controls on your computer:
In Internet Explorer, on the Tools menu, click Internet Options. On the Advanced tab, scroll down to the Security section of the list. Select the Allow active content to run in files on My Computer check box, and then click OK.
To accomplish this via the Registry, modify the following registry value:
HKCU \ Software \ Microsoft \ Internet Explorer \ Main \ FeatureControl \ FEATURE_LOCALMACHINE_LOCKDOWN
In the right-pane, create a new REG_DWORD named iexplore.exe and set it to 0
Values:
0 - Allows a Web page to run active content in your computer
1 - Disallows a Web page from running active content in your computer
To allow any CD to run scripts and ActiveX controls on your computer:
In Internet Explorer, on the Tools menu, click Internet Options. On the Advanced tab, scroll down to the Security section of the list. Select the Allow active content from CDs to run on My Computer check box, and then click OK.
May 15, 2011 | Computers & Internet
Im unable to access my fb games lately. When I click the app on my fb page it says, page requested not found. The link doesnt look the same. When I change it, it switches back.
It is possible that you enabled Secure Browsing (https) on your account. Many games do not allow you to have the https connection. To turn this off you could click on Account, then Account Settings at the top right. When that page loads there are several options. Towards the bottom is Account Security. Click Change. Uncheck
Secure Browsing (https) Browse Facebook on a secure connection (https) whenever possible
Click Save and try again. When you are done playing your games if you are still concerned about your security you can repeat this process and then check that box and save when you are finished gaming.
May 04, 2011 | Facebook Computers & Internet
Adobe Flsh player cant be downloaded in my Laptop.
If you are using IE, your security settings may be prohibiting the installation of the Flash player.
In IE, Open Tools->Internet Options. On the Security tab, select the Internet zone and move the slide control to Medium. This setting should allow IE to download Flash.
Next, go to the Advanced tab. Under Browsing, check the box to Enable Install On Demand (Other). This will allow the Flash installer to run.
If you are still having problems, go to the Adobe Website. At the very top of the title page, you will find a link that will let you download Flash manually. Follow the directions on the screen, taking note of any messages that might appear in a yellow bar at the top of the main IE window.
Have a great day,
Bhautesh.
Feb 23, 2010 | Computers & Internet
I can't seem to download flash or reader. When I go to adobe the security bar pops up but won't allow me to click on it to allow active X. I've checked my security preferences and allowed active x The page...
Which browser are you using?
First thing would be to try downloading flash using a different browser, such as Firefox or Safari. If that works then you know there is something with your browser security settings. With most browsers there is a way to 'reset' to your original state, and/or to mark Adobe as an allowed site, which may solve your problem. Let me know if this helps!
Oct 14, 2009 | YouTube Videos
Have net page that wont delete punched in site site appearred then security popup blocked further access
You either have that type ofsite blocked by you internet content on your security control or on your system under tools>internet options>content or both. Have you tried ctrl/alt/del under the applications tab to get rid of the page? You can highlite the running page and hit end task to get out of it. otherwise you can reboot. However, if you wish to view this type of page, you need to change you settings in your security software and in internet tools
Aug 03, 2008 | HP Computers & Internet
Installing active x control
it appears at the top of your web page on certin pages you get it at the top off microsoft update page a yellow bar appears just click on it and install active x this should sort you out
Mar 04, 2008 | Computers & Internet
Popup problem
Your internet setting is very correct, that is the protection setting of your explorer either the site is secure or not. but you can correct this by allowing the active X if ever will pop -up again. Either you can reset you internet setting by going to the internet option then click "security" tab. You can reset all internet setting there.
Dec 18, 2007 | Compaq Presario 5000 PC Desktop
Internet explorer - Active X
In security setting enable Running activeX controls and pluggins. Change it to medium. And convert all the options in security settings to default level.
Sep 23, 2007 | Microsoft Windows XP Professional With...
Adobe Photoshop 7.0 for PC Logo
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
