Question about Microsoft Xbox 360 Console
Xbox Mine will not load, the tv screen just stays blue, you see the light around the on button on the console it self circle 2 times and thats it. it's not even 4 months old
    President:
  • 4,402 Answers
Http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on Dec 08, 2007
SOURCE:
My xbox 360 controller dosent work!I have a black controller and a white one,the white one dosent trun on it just flashes like a freaking comilean!
There's a little button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around thexbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I think there's a little symbol of air waves next to the button.
Try this it should fix your problem
Feb 28, 2011 | Microsoft Wireless Controller for Xbox 360...
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
My slimline ps2 will play dvds but when I put in shadow of the colossus the system acts like it is loading by the loading circle on the lower right side of screen then the screen stays black and the game...
Take a Q-Tip and do light circular motions on the laser eye.
Often the case, you may just need to take a soft cloth and clean your video game disc.
It's one of the two.
Jul 15, 2009 | Sony PlayStation 2 (PS2) Console
Tv continues to turn on and off by itself..
When it shuts off by itself, does the blue circle screen under the "Samsung" label show a picture of a light bulb? If so, it's probably time to replace the lamp.
Jan 24, 2009 | Samsung HLP5085W 50" Rear Projection...
PS2 Reset led
same thing is happinin to mine
Jun 07, 2008 | Sony PlayStation 2 (PS2) Console
Ps2
you say it wont turn back on but it has power.
is the light red ( stand by )
or do you have green and blue lights
Did it fall????
try cleaning the disk and the lens
you can also run the auto diagnosis..
HERE'S HOW
Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point. NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
the above is a copyright of the PS2 user guide
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
