Question about Sharp LC-32GA4M 32 in. HDTV-Ready LCD Television
Sharp LC-32GA4X Power problem
I have a LC-32GA4X that won't power up. After a power outage, I have the red LED flashing only. There's about 55vac on the white and black wires at the left rearĀ verticalĀ board, but TV does not fire up..
Any help will be appreciated
Tezza
(vk8ktc@dodo.com.au)
  • mbik Aug 29, 2008
    I have the same LCD same problem. Flashing red light but not powering up. I ran out of ideas. Does anyone have an answer?
    Thanks!
  • mistajace Oct 14, 2008
    i have the same problem! obviously the experts here dont have the answer! if anyone finds out let me know and i will do likewise:)
    Cheers.
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Posted on May 15, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
SOURCE: Flashing OPC/DL light
Here's what I did to fix issues with my 37D5U - do at your own risk:
***Follow the instructions below to fix the same issue in your LC-37D5U tv***
Do this test first to confirm the failure:
(1) Connect the cable line to the tv.
(2) With the tv unplugged, hold down the Input and Volume-Down buttons simultaneously, then plug in the tv.
Expected result:
(a) You should hear the tv come on in the service mode; the OPC/DL and power lights on the front of the tv should turn green and blue, respectively.
(b) The broadcast sound should come through the speakers, but you will probably still have no picture or back light.
If your test yields the expected results, proceed to the fix.
Fix
Parts Needed
(1) Part type: Fuse
Location on circuit board: F705
Official Part No: QFS-A1154SNEZ
Replacement Part No: BK/PCB-1-R (Mfg: Cooper Bussmann - about $2) or the original QFS-A1154SNEZ (Distributor: Sears Parts Direct - about $14)
(2) Part type: Mosfet (4 of them)
Location on circuit board: Q723, Q721, Q719, Q717
Official Part No: k3469
Replacement Part No: FQPF13N50C or FQPF13N50CF (Mfg: Fairchild Semiconductor - about $2 each)
Fuse F705 is part of the circuit on the power supply that powers the inverter circuit, and the inverter switches on the back light for the tv. The mosfet at location Q723 was suspect when I tested it, so I went ahead and replaced it and the other three mosfets "chained" to it as preventative maintenance. Parts can be bought from digikey.com - digikey is usually a same-day shipper with the best prices, so I use them. USPS Priority shipping is the best bang for your buck.
Tools Needed
Philips screwdriver
Soldering iron
Desoldering braid or some other solder remover
Light bulb socket that has two wires running from it and a clear 100-watt light bulb - Home Depot sells the sockets. Alternatively, you can use a 2K ohm/10W resistor
Multimeter - not necessary, but helpful
Procedure
(1) **Important: Make sure the tv is unplugged**
(2) Remove the back cover and stand - there are a bunch of screws holding the back cover on. You can either mark the screw locations and bag the screws or do what I did: Unscrew the screws, leaving them in their holes, then slowly lift the back cover off and carefully set it down with the screws intact.
(3) Set the tv on a flat surface with LCD panel facedown and remove the AC power cable.
(4) The board you want to work on is the power supply board (see pic below), which is the board where the AC power cable connects. Carefully detach the connectors that connect to the other boards in the tv from the power supply, then remove the screws that hold the power supply to the back of the tv and lift it off the tv by holding it by its edges.
(5) Locate the four large 450V capacitors at locations C734, C709, C710, and C852 without touching them (they look like soda cans). Flip over the power supply board. Touch each wire of the socketed light bulb or resistor for about 3 seconds to the negative and positive leads of each large capacitor, respectively; polarity is irrelevant. This discharges the high voltage from the capacitors so you don't get shocked while working on the power supply. The voltage usually slowly dissipates on its own, but it's better to be safe than sorry when you're talking about a potentially lethal 450V. Check the voltage with your multimeter in the appropriate DC mode to verify that the capacitor voltage has been drained; if you don't have a multimeter, just continue on.
(6) At this point, you can verify that the fuse at location F705 (looks like a small black box) has indeed failed by holding the multimeter's red and black probes on the fuse's leads with the multimeter in continuity mode. If you have no continuity, the fuse has internally failed; proceed to the next step.
(7) Desolder the fuse from location F705 and desolder the mosfets from locations Q723, Q721, Q719, and Q717 then replace with new components.
(8) Put the power supply board back in the tv, using just a couple screws to hold it in for now. Reattach the connectors to the power supply.
(9) Attach the broadcast cable line.
(10) Reconnect the AC power cable to the power supply (don't plug it into the wall socket). Hold down "Input" and "Volume-Down" simultaneously, then plug in the tv. The tv picture and sound should come on.
(11) With a small screwdriver or other probing device, depress the Reset button, not the System Reset button; it's the last recessed button below the cable jack on the back of the tv. The tv will reset, then you should get sound and a picture from channel 2.
(12) Reinstall the remaining power supply screws, back cover, and stand.
Posted on Dec 30, 2010
  • 16 Answers
SOURCE: LC-42DH77E Sharp No picture Green led comes on
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Posted on Apr 30, 2011
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
LC-42DH77E Sharp No picture Green led comes on then red LED comes on after a short while RED LED flashes twice then reoccurs .
Apr 30, 2011 | Sharp LC40E77U LCD TV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lc-22sv6u won,t power on. no green light.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
May 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp LC-32GA4M 32 in. HDTV-Ready LCD Television Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
