Question about Tomtom GO 700 GPS Receiver
GO700 Hi My Tom will not make a connection! It comes on and has a dull blue screen with lots of question marks n says waiting for signal...... I have tried the reset button but it does not put it right.. No menu either?
    President:
  • 4,402 Answers
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 22, 2008
SOURCE:
Stuck in "waiting for a valid GPS signal...." at the screen it display " waiting for a valid GPS signal
you need to connect tom tom to the computer and download new updates from tom tom home.
Oct 07, 2009 | Tomtom ONE GPS Receiver
Change TomTom Go700 from yards to meters
I have a 720 but I suspect it will be the same or similar.
Tap the screen and then Change Preferences. Use the forward arrow to scroll to the relevant page (5 on mine) where you will find Set Units. Tap this and then change whatever units you wish.
Sep 24, 2009 | Tomtom GO 700 GPS Receiver
Tom tom one wont detect gps signal
my tomtom wont get a signal and is saying are you in a building?
Jun 18, 2009 | Tomtom ONE GPS Receiver
Waiting for valid gps signal
Try resetting your device. Depending on the model you have, this is done by either using the pin or holding down the power button for about 15 - 30 seconds. You'll know the reset has been successful when the legal agreement come up when it comes back on. Once this is done, go outside and on the device, go to the satellite detail screen and wait until several (about 4) of the bars are 75% or higher (they should change colors). You should go the the regular screen after that and you should be able to navigate again.
Mar 31, 2009 | Tomtom ONE GPS Receiver
Just says waiting for gps signal
Tom Tom needs comms with GPS satellites orbiting the earth.
Make sure you are outside your home so the GPS can find these signals. Initially it may take up to 5 minutes to make these connections. One the satnav knows where it is, all subsequent connections will be a lot quicker. :)
Some vehicles have windscreens with special coatings which prevent the satnav initialising with GPS satellites. If this is your problem, the only solution is to purchase an external antennae for your satnav. :(
Mar 08, 2009 | Tomtom One XL GPS Receiver
Tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
Feb 11, 2009 | Tomtom GO 910 GPS Receiver
Touch screen not working. frozen
i have a tomtom xl i conected it to the computer and now the touch screen doesnt work it turns on ok and displayers the map but if i touch the middle of the screen it selects some thing else is there a way to reset the touch screen back to the centre if you can help plz email me at [email protected]
Sep 23, 2008 | Tomtom GO 700 GPS Receiver
Cant reset tom tom
I have now resolved my Tomtom 1 V2 problem (posted 12th Nov 2008).
I emailed Tom tom directly, describing the problem I was having, they responded almost immediately.
Tomtom could not have been any more helpful, the advice they gave me was spot on, and absolutely correct.
Not only did they solve the error I had with my unit, but they made it work much better than it ever had.
Briefly, I was told to join (for free) Tomtom Home, then delete all of the operating system on my satnav and download the latest Tomtom operating system, plus a few other upgraded programs.
I am no computer genius, and admit to being more than a little apprehensive in doing this, but, it could not have been a more straight forward or simple procedure.
As before, my Tomtom now works so much better, faster and with far more features.
Another benefit of being a member of Tomtom Home is that you are offered many products such as map updates at greatly reduced prices.
Regards,
Chris Vince
Sep 17, 2008 | Tomtom ONE 3rd Edition GPS
No gps signal
I have had my GPS( TOmTOM One) on Waiting for Signal for 2 weeks now and I finally fixed it.
My symptomtoms (word play) were no signal at open areas, when connected to Tom Tom Home it showed exactly where I was and worked through the PC but when disconnected back to the same thing.
I called Tom Tom CS and nothing, FLash did nothing, factory defaults nothing, and updating did nothing.
What I did:
I charged the unit completely.
I took a paperclip and while off pressed on the reset button at the bottom by SD slot. I held it there for 30 mississippi's.
I did not turn it on after letting go.
I went outside to my car (parked on roof of parking lot) turned it on and set it on my dash vertically.
I left and came back in 1 hour and wallaaaaa. It is working perfectly!
Let me know if this fixes it.
[email protected]
Oct 03, 2007 | Tomtom Go Plus GPS Receiver
Tomtom GO 700 GPS Receiver Logo
107 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
