our disherwasher keeps coming up with the letter (F) on the front screen goes any one knw what this is. I have no water coming through the machine have checked the hoses the are not blocked.
what is your model number? list it so I can look it up, also check to see if there is any water standing in the bottom pan,not inside where dishes go, down behind where toe plate is.Remove toe kick plate,remove panel behind kick plate.If there is water inside lower pan there is a float switch that will trip when water is present.only the drain pump will work and no water will come in unit.If there is water in lower pan you have 1 of 2 problems,1 you have a leak 2 the unit is oversudsing... to much soap. Dry up water in lower pan and styrofoam float switch will reset run unit check for leaks, put 2 tbls of cooking oil inside dishwasher to get ride of oversuding issue
My model 665 Kenmore dishwahser has become loud and the top rack glasses are no longer getting...
(More)
My model 665 Kenmore dishwahser has become loud and the top rack glasses are no longer getting clean.
