my xbox works fine sometimes but cant load games then i swith it off and on again and it shows the RROD in sectors 1,3,4 and when i get the error code it shows 0102 so what does this mean? am i screwed?
-   my xbox works fine sometimes but cant load games then i swith it off and on again and it shows the RROD in sectors 1,3,4 and when i get the error code it shows 0102 so what does this mean? am i screwed? -   Guest
Mar 07, 2008
-   thanks-   Guest
Mar 07, 2008
-   cool-   Guest
Mar 06, 2008
-   Xbox 360 wont load anything, it turns on and shows the 3 rings of death-   Guest
Solution #1
posted on Dec 08, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my 360 crashed a few days ago and had the same code(0102).
ive tryed everything to fix it, but the best way is to send it to microsoft if your warenty hasent ended.
though it's most likely GPU related literally means the
console does not know what is wrong. possibly a short or cold solder
joint somewhere. So far there is 1 major theory for what causes most of
these errors is that the Ram, CPU, or GPU are not soldered properly to
the mother board due either to poor manufacturing or excessive heat up
and cool down cycles that stress, weaken and eventually break the
soldered connection.
There are two theories to fixing this one deals with
the "X" clamps that hold down the chips. The other involves
re-Heating the chips. DO NOT attempt either of these if
your console is still under warranty. If your console is still under
warranty return it to the store where it was purchased or call MS to
have it replaced. I have also heard of limited success by simply
switching the AV cable from "HDTV" mode to "TV" mode.
I have been receiving Error 74 prior to this new one that I just got which is 0020 Xbox Error. Thank...
(More)
I have been receiving Error 74 prior to this new one that I just got which is 0020 Xbox Error. Thank you.
The power on our xbox 360 doesn't turn on. The power box light is orange.
Everything is plugged...
(More)
Everything is plugged in just fine. We hadn't even touched our X-Box in a couple months or something. and then it randomly just wouldn't turn on. The front panel is a little bit loose, I don't know if that would have some sort of contribution to the problem.
After months, today we retried it and it still just won't turn on.
Is there any possible solutions?
trying to connect my xbox to my PC. It gave me an 8 digit code to put in on xbox.com/pcsetup. I go...
(More)
trying to connect my xbox to my PC. It gave me an 8 digit code to put in on xbox.com/pcsetup. I go to the site but not sure where to go.
My xbo 360 does not turn on. The power cord and box has the light on but the xbox itself does not...
(More)
My xbo 360 does not turn on. The power cord and box has the light on but the xbox itself does not turn on
