Question about Samsung YH-925 MP3 Player
Loading library error
I connected my MP3 player to my computer and tried synchronizing it to my play list on my compter and after disconecting it my MP3 player froze on the "Loading Library" screen.
if i reset it and conect it to my computer im able to veiw the files on my computer however, once i disconect it from my computer it gets stuck on the same screen " Loading Library".
  • steers Nov 28, 2007
    how do i format my player
  • Anonymous Feb 29, 2008
    I have the same problem. It's not actually stuck, it just takes a very long time, like half an hour or more depending on how much stuff you got on the device and it 'loads the library' every time you change the device's content.
    I suspect it may be related to a message I got from windows media player 9. When wm9 detected my device it gave me a message saying it had to 'rebuild the database' or something like that after which it gave me a success message and let me manage my player.
  • 790 Answers
Format the player once and load again ...
Posted on Nov 28, 2007
I am trying to synchronized a playlist to a usb from windows media player. But it always stops at different percentages etc, 4%, 8%, 15%. The usb is 8gb and its always empty when I start synchronizing
First make sure that all the files in the playlist are supported by the device (all mp3 files)..also ..make sure that the playlist you are trying to sync contain only files that are in the library of windows media player ..(to be sure ..better scan all hdd again and add all media files on the library again )..
be sure that you do not have files in the Play-list that were originated from a disk or some device that it is not in use at the moment...cause this is the main reason for these kinda errors..
If it do not want to work ...better look for the device in My computer folder and load the files manually in the device(removable storage) using the copy/ paste feature..
Dec 25, 2010 | Computers & Internet
Wen i delete music from the library in windows media player it also deletes it from my philips gogear mix how do i stop this
Playlists to sync on the player can be set in Windows Media Player.
When selecting the Library or Sync tab in WMP full view, the GoGear is visible on the left side in the list.
The player can be either connected seeing the player's icon or not connected seeing the player's map name.
Right click the GoGear Mix and select Setup Sync...
The box, Sync this device automatically probably is selected.
Prevent the player from unattended synchronizing by unchecking this box: Especially when you're removing lists on the computer frequently.
Setup the the playlists to sync first and synchronize manually after that.
Temporary "Sync this device automatically'' must be selected, to be able to edit the playlists to synchronize.
On the right half of the Device Setup screen there''s the "Playlists to sync''.
Under playlists to synchronize, first remove all playlists or those you are going to delete in the library, before synchronizing.
When needing more information, just post a comment.
Jan 06, 2010 | Philips GOGEAR SA6045 MP3 Player
My Camnex mp3 player will not play video. When I open the files in it on the computer with USB and put videos in they go inside but when I choose Video later on the mp3 player it says "no files". HELP...
You need to check the file format of the video that came from the computer (MP4, WMV, AVI etc.).
You have to make sure that the MP3 player supports the file format of the video that came from the computer. Because if the player does not support it, it will not either play or show up.
Have a great day!
Sep 25, 2009 | Mach Speed TRIO Onyx MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer.
3. When connected the LCD Display will either say “USB” or “MTP”.
4. Press the “M” (mode) button to switch between “USB” and “MTP” mode.
“MTP” mode will only work, when your player is connected to Microsoft
® Windows® XP and Windows® Media Player 10.
The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
Can't transfer data files
I was afraid of that. The file that you are trying to load has a DRM license on it that has a fixed-term license. It will play on your player for about a wekk or so, and then it is unusable except on the computer itself.
Most mp3 players that claim to support audiobooks don't really support most audiobooks - or don't play them correctly. Audiobooks that are in mp3 format (as in, NOT Overdrive) will give you the fewest problems.
Mar 02, 2009 | SanDisk Sansa Clip MP3 Player
Synchronize to continue your music subscription
The "synchronize files to continue" is annoying, and you are likely to get it again. If the music files on your player came from Rhapsody, the short-term solution is to re-synch the files through Rhapsody itself. If your subscription to Rhapsody, Overdrive, etc. ever expires, you will also get this message. The only long-term way around this problem is to only load songs that are in mp3 format (Rhapsody has an Mp3-Only subscription, which is different from its regular subscription; Limewire is another choice - but it is prone to have viruses, and some ISPs will cut off your broadband if you use the service). If you wanted to erase all songs and start over from scratch, you could update the firmware on the player - it will have the side effect of erasing everything on the player.
-Tha Mp3 Doctor
Feb 14, 2009 | SanDisk Sansa e250 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa clip mp3 1GB problems
the best way to solve the problem is to return it to the store! let the sudisk solve the problem and only after that to sale them
Mar 18, 2008 | SanDisk Sansa Clip MP3 Player
Samsung YH-925 MP3 Player Logo
96 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
