Question about Pinnacle PCTV 110i (210100458) Video Capture
How to get compatible to vista version OS
I installed vista in my system and i got a problem while installing drivers of pctv it is asking me to upgrade the vista version from pinnacle website.where will i get that updated please send a solution to my problem
  • ghostboy Feb 11, 2008
    got 110i tvcard with os vista ultimate i was using it fine with xp home with the rave software now trying to run it with vista it say wrong os help ps
  • Anonymous Jun 08, 2008
    not working on vista
Its a weird solution but if u download the 32 vista driver (analog or not dunno which i currently use) and then download the american tvtogo software and install this. Now i have done this suddenly my mediacenter does recognize my 110i device (which should have reached it end of life status HAHA **** u pinnacle)
Posted on Oct 23, 2008
  • yorno Oct 23, 2008
    dont bother tryin my solution it seemed to work but it doesnt
  • 790 Answers
Search in pinnacle website ... u will get vista supported installations
Posted on Nov 28, 2007
Pctv tuner will not install
What is your Operating System? and is your stick compatible with the OS you have installed?
Feb 17, 2013 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
I cant install it on windows 7
Try downloading the Vista driver. Make sure that you select the 32- or 64-bit version, as needed, from http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_Z605&focusedTab=DOWNLOADS#4 . Click on filter to get the correct file. To check the version of Windows that you have, click Start > Control Panel > System and Security > System. If you see x64 after the OS version name, get the 64-bit driver. Otherwise you need the 32-bit driver.
Make sure to disconnect the data cable between the computer and the printer, if you have connected it. Uninstall any problem driver (generic from the Windows OS or a failed Lexmark driver install) before installing the new driver.
If you still have problems, uninstall the driver again. Then use the compatibility mode. Right click on the exe file that you downloaded from Lexmark and choose Properties. Under the Compatibility tab, check the box for "Run this program in the compatibility mode" and select Vista. Then right click again and choose "Run as Administrator".
I hope this helps.
Aug 11, 2011 | Lexmark JetPrinter Z605 Color InkJet...
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
Tuner is designed for windows xp/vista but i have system running windows 7 and the tuner driver cannot intall correctly. i need updated driver that can run on windows 7. Thanks
Have you tried running the installation in compatibilty mode?
uninstall the tuner driver and right click the install file and select Troubleshhot compatibilty. This will then ask if you want to use recommended settings or troubleshoot compatibility, select the second option. Then choose "ran in an earlier version" and "needs extra permissions" you will be asked which os it worked in previously so select xp or vista and click ok. You will then be presented with another box, click on the start program button, go through the installation process as normal, when you have finished click next on the box with the start program button, at the bottom click next and follow the prompts.
May 05, 2011 | Computers & Internet
I am having installing my dynex wireles g usb adapter because it says the install driver is not compatible with windows 7 64 bit. Is there a way to install the driver?
I'd suggest installing the device drivers in the Compatibility Wizard. Remove that hardware device in Device Manager, right-click on the driver executable/installer file and select the Compatibility tab; click the checkbox before Run this program in Compatibility mode for option and select Windows Vista in the list-down box; then try installing the device driver. In addition, you can use the Windows XP driver for testing.
If the problem still persists, please understand that Windows 7 is a new operating system (only the beta version) and whole driverstore has been reprogrammed; some old driver is not compatible with new OS. I suggest that you should wait for another period of time till the retail version is released and push the vendor company to upgrade their device driver. Thanks for your time and understanding!
Good Luck!
Feb 28, 2011 | Dynex Wireless-G USB 2.0 Network Adapter
I have 'generations' family tree software from Cendant I have 'vista' but it won't work. What can I do?
You can right click the program and try troubleshooting compatability. otherwise it wont work with vista. To be honest, Vista is the worst OS ever. Upgrade to windows 7
Jan 16, 2011 | Computers & Internet
I have lost my software for Epson Perfection 1260 Scanner. I need to install in my new computer with windows 7. How?
go onto epsons website and download the driver or the installation file/ folder then process with any insruction enjoy
Dec 18, 2010 | Computers & Internet
Problem with Pinnacle PCTV 50e USB 2.0 TVtuner
hi here is the link for you...hope this helps please vote thanks
http://www.pctvsystems.com/tabid/62/default.aspx/Downloads/Driver/tabid/123/language/en-US/Default.aspx
just look for your tuner and it has the vista drivers there for you
Jul 04, 2010 | Pinnacle PCTV 50e (210100474) Video...
Cant install my pinnacl 110i on windows 7. Any one had success with that? It was working perfectly well with Vista. But I'm a ****** for pain! :D
Download updated VISTA drivers from here: http://cdn.pinnaclesys.com/SupportFiles/PCTV%20Drivers/ReadmePCTV.htm
If the driver have an installer try to install from it.
If not success try to run the installer in compatibility mode (right click - properties - compatibility tab - run in compatibility mode with WINDOWS VISTA)
If all of those steps faill try to MANUALLY install the driver:
Go to device manager, select your device, right click on it and select update controller software - try to find it in Windows Update (online)
If not driver available online try again, but select the "find on my computer" option, and select a folder containing the drivers.
An excellent website to find drivers and solutions is: http://www.driverguide.com
Aug 26, 2009 | Televison & Video
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Pinnacle PCTV 110i (210100458) Video Capture Logo
301 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Greg Ulan
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
