Question about LG L1520B 15" LCD Monitor
Problem in monitor
Sir in my monitor screen.screen is moving upward side automatically.
feel like magnetic effects.but no magnetic things are around .
when i beat the table it acquire the good position then again
show the problem.
it is hardware problem or software?
monitor is 15" LG
time period- 4 yrs
  • 790 Answers
Hey vinay i guess its hardware problem ... coz software doesn recognise u hitting it ,,, ; )
Posted on Nov 28, 2007
SOURCE:
My Magnavox combo tv/vcr/dvd rca old school has purple tint on the left side of the screen. Any suggestions?
There is something magnetic near the side of the TV that is causing the distortion. Tube sets automatically degauss (get rid of) magnetic distortion when it turns on- unless there is a magnet nearby. Could be a speaker magnet or a coiled in a circle electrical extension cord nearby. Check to see. Then turn off the TV for a min, and see if it changes things. When you turn it back on- the problem should go away. There is also a cheap degaussing coil you can purchase to clear up the problem. But try moving the wires around first.
May 31, 2017 | RCA Televison & Video
Monitor has a purple tint.
Hi there, Make sure there no speakers or electric items next to the screen.. especially items like speakers that contain magnets. The magnets in the speakers tend to affect the screen and it will change the closer the speakers are to the screen. Table lights in some cases may cause this effect. So just try moving the electrical devices away from screen.
Hope this helps,
regards
Jul 22, 2011 | Samsung SyncMaster 172 B 17" LCD Monitor
I am using Hansol 730E monitor and recently it start to make slight vibes on screen in horizontal way. I tried to change refresh rate and its no good. I tough that it is magnetic field but i moved monitor...
Being a rare tube monitor i am inclined to say it is nearing end of life. You have done the right thing by moving around unless you are moving other magnetic or power source items with it. Have you tried connecting to another computer - subbed out cables to eliminate that issue? testing on another computer who help determine if monitor or not. might be video card??/ since you are having DX issues I would start there. There is not much more you can do that is not dangerous - ie - increasing the voltage etc..
Jun 13, 2011 | Hansol 730E 17" CRT Monitor
When i turn on my tv, the screen has like rainbow color all over it. i found out if you hold a magnet up to the screen, the color moves if you move the magnet. no picture of anything,,just color i...
To fix this, you need to do something called degaussing. You should keep magnets away from the screen in the future, because they cause this problem.
The first thing to try is to turn it on and off, making sure that all magnets and speakers (which have magnets in them) are kept far away from it. This will activate the monitor's auto-degausser if it has one. If this does not help, this guide: http://www.wikihow.com/Degauss-a-Computer-Monitor gives a couple solutions, including using a soldering gun (not a soldering iron), illustrated in the video below:
With a powerdrill:
Or investing about 60 bucks in a degaussing coil like this which is a guaranteed fix:
One other trick that might work is to take an old CRT monitor ("fat-screen" rather than "flat-screen"), hold it up to the tv screen to screen, and turn it on and off to have the monitor use its own degausser. The monitor may have a button to activate degaussing, or it may be in the menu you can bring up with the buttons on the bottom of the screen.
If you don't want to deal with any of this, a tv repair shop will degauss your tv for you quickly.
Feb 28, 2011 | Philips Magnavox 27MS343S 27" TV
I have blue curved shadows of white letters at the top and bottom of screen. Other wise the colors are normal. It appears to happen for the things like banner in a TV program etc. What could be the...
Question ?
Are your speakers closely related to your tv ?
The reason I am asking is sometimes the magnetic
interference from your speakers will effect or affect your
tv screen.
Usually, it starts at the left and right side but with todays
set ups it could start anywhere.
A tv repair man did a magnetic wand type deal on and old
projection tv I had and it fixed the problem.
I also had to move my speakers farther away because they
were not magnetically shieled enough.
good luck
Jan 26, 2011 | Televison & Video
Polar speed censor not working can I replace battery
The S410 watch is not designed to pick up a bike speed censor.
Detach the sensor from your bicycle.
1. Open the sensor by removing the two small screws, counter-clockwise, with a small screwdriver.
2. Lift the case off carefully. Hold the sensor cover upwards so that the PCBA (printed circuit board assembled) stays in the case.
3. Remove the PCBA carefully.
4. Press the battery holder gently. Release a hook of the holder from the opposite side of the PCBA and lift the holder upwards. Remove the old battery.
5. Insert a new battery with the plus (+) side facing up and press the battery housing gently so that it is attached to the PCBA at all corners.
6. Put the PCBA back into place. Attach the magnet by rotating it around the spoke before putting the metal cover on the magnet. Install the magnet at the same level as the sensor. The magnet must be facing the speed sensor. Or Attach the screw magnet to a spoke at the same level as the sensor. The magnet must be facing the speed sensor. Fine-tune the positioning of both the magnet and the sensor so that the magnet passes the sensor closely but does not touch it. The maximum distance between
the speed sensor and the spoke magnet should be 0.2"/ 5 mm. Once positioned correctly, tighten the cable ties securely and cut off any excess cable tie ends.
note: when you take apart and put back together the seal will no longer be watertight as these are pressure sealed.
Apr 19, 2010 | Polar S410 Heart Rate Monitor
Dell XPS M1210 laptop was set next to a speaker and now the bottom half of the screen is grey
It's due to the magnetic field interferences from the speaker. At the first place, you shouldn't keep it near the speakers.
Always keep speakers far away from the Monitor.Now turn off the monitor and turn it on again,hope it solve the problem. You may even need to restart the system.
Moving magnetic fields (such as from an electric motor) can cause flickering when near a CRT screen. A static magnetic field, such as from your computer's speakers, can cause color shifts or incorrect colors in the area near the magnet. This color shift is caused by parts of the screen becoming magnetized. Occasionally the color shift will remain after you remove the source of magnetism. To help reduce or eliminate the color shift, you can use the degaussing option on most monitors. Most newer monitors automatically degauss when you turn them on, while older monitors might require you do to it manually. Most monitors have a button or menu option that enables you to degauss it manually. Degaussing a monitor will de-magnetize the inside of the monitor, removing the color shift. Unfortunately, if the monitor is exposed to the source of magnetism for too long, degaussing will not be able to clear it up, requiring you to repair or replace the monitor.
Feb 08, 2010 | Dell InspironTM XPS M1210 Notebook
There are 3-4 patches of colours on the sides of screen what is the problem in the monitor ?????
Sounds like a magnetism prob on your monitor. It happens occasionally and/or if a magnetic force has gotten close to the screen on CRT monitors. Speakers have magnets inside and many people place their speakers right next to their monitors. For your LG Studioworks 700S. I located a manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/700S-_E
Inside, on page A7 it indicates that the monitor has a "Degauss" feature. Activate it and your screen will jump around a bit before straightening out. This helps to restore the image.
Jun 11, 2009 | LG Studioworks 700S 17" CRT Monitor
Tv screen has got 2 green spots
your monitor has came in contact with some magnetic material remove all the things containing magnetsfrom around it and leave monitor unplugged for 1 day and then start it will work fine
pls rate my suggestion
thankyou for using fixya
have a nice day
Feb 20, 2009 | IBM G 40 Monitor
COLOR SHADOW
that is called a magnet effect it means u have a strong current some were do u have a cd player or speakers to close surround sound to close if so move them away till it fades
Jul 05, 2008 | Panasonic PT-51HX41 51" Rear Projection...
LG L1520B 15" LCD Monitor Logo
100 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
