Question about Garmin Edge 305HR GPS Receiver
Suddenly turning off
My unit is 1 year old. recently i have noticed that it turns off all of a sudden while riding even there appears to be enough battery. when i turn it back on again there appears to be 2 or 3 battery strength but it again suddenly turns off again.
Your battery is dead. You'll need to return it to Garmin for repairs. Mine did the exact same thing. Functioned fine in the cradle - showed full battery - but shut off immediately upon removal. They know about the problem and shipped me a new unit for free.
Posted on Feb 06, 2008
GE refrigerator GFE27GSDASS not cold enough, putting a fan behind the unit fixes this.
Check to see if the condenser fan is turning. Right next to the compressor
Jun 20, 2017 | GE Refrigerators
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
450 husqvarna rancher stopped suddenly now the engine wont turn over, any suggestions? Less than a year old and minimal use and im using 50:1 gas mixture
If turns over and won't fire up it can be several things. But yours will not turn over, so it has seized. There may not have been enough oil in the gas. This needs a serious repair or engine replacement. The cylinder will need to be stripped and checked possibly piston/rings/ cylinder will need replacing, and they may never be as good again. Consider replacing the engine unit as a whole.
Dec 18, 2013 | Garden
I have an old Simpson's-Sears Craftsman Rototiller. It has been running fine, but suddenly stopped. I noticed there was no spark. I removed the rewind starter assembly and noticed that the flywheel...
You are on the right track. They use aluminum so that any sudden stop to the crankshaft allows for that little bit of give after the sudden stop to allow engine parts time to slow down. A complete sudden stop could mess up the rods, valves, and possibly the crank itself because of inertia. A steel key wouldn't shear or "break" as easily and would allow for a complete sudden stop. All the engine parts (due to inertia or stored energy) do not easily immediately stop. The aluminum key shears and has a braking effect on the inertia driven engine allowing it to slow down further. Install a new aluminum one (very cheap) and your timing issue there is solved. The replacement key is a very normal, standard Briggs part. They usually shear on a lawnmower when the blade hits an immovable object. I don't know if your machine hit anything. but now you know.
Mar 31, 2011 | Briggs & Stratton Garden
Mower suddenly shut off and engine starting smoking. Now it won't do anything. seems to be locked up. Sears craftsman riding mower only 1 and a half years old. has oil and gas.
About the first thing I would do is to pull the plug lead(s), tilt the mower up (resting it on something solid) and see if the motor shaft could be turned at all. I suspect you initial thought that it is locked up is correct.
May 15, 2010 | Craftsman Replacement Belt for 42" Deck
I updated my Sansa Clip yesterday when I got the regular reminder through the updater but now the volume is very low even when the slider is at max. The manual says it can be adjusted through the settings...
After a update the player needs to be reset. To reset the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Mar 17, 2010 | SanDisk Sansa Clip MP3 Player
Power steering suddenly turns very tight
make sure the belt is tight but not too tight.
Jan 04, 2009 | 2000 Toyota Camry
Pivot arm in telescoping downdraft system sticks when closing
Having the same problem. Unit worked well for 1 1/2 years and then suddenly it dropped after I was thru using it and pushed the arrow for it to go down after it dropped the power wouldn't turn off - had to unplug it.. Repairman came out , took it out, lubricated it , re-installed and next time it went up fine, vented fine but when it went down it dropped again and power wouldn't turn off again. I am hesitant to call him out again unless I can figure out what else might fix the problem. I have noticed that the top piece now seems to be bowed a bit. I guess I can have him take out the cooktop but think there must be enough room for it if it worked fine for the 1 1/2 years. It is a soapstone countertop.
Dec 28, 2008 | GE Profile JVB67 36" Telescopic Downdraft...
Samsung D600 not switching on
take the phone to a mobile repair center and have them try to revive the phone for you.
Feb 29, 2008 | Cell Phones
Garmin Edge 305HR GPS Receiver Logo
70 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
