Question about Edirol UA-101 External Sound System
Problems with sound that is coming from computer (output monitoring)
Playing instruments trough edirol UA-101 causes soundproblems in output monitoring. When we have playded some time, abou 15seconds, music turns out metallic, distorted. when I turn direct monitor volume to input monitoring, sound turns out normal. Wheb we record it to Sonar 4 home edition, everything sounds normal. Computer,that I'll use is HP laptop with USB 2,0 and Windows XP
    Novelist:
    Champion:
  • 244 Answers
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Posted on Nov 28, 2007
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Ua 101 driver won't install on windows 7 64 bit
Officially Microsoft says that 32bit drivers are not supported on a 64bit system. Check hardware manufacture for updated drivers. Good luck.
Aug 31, 2012 | Edirol UA-101 External Sound System
Edirol ua-5 flashing power light flashing
Be aware that SCMS "prohibited" recordings will trip this flashing light, and will not output. You will have to make an analog copy.
Feb 25, 2012 | Edirol UA-25 External Sound System
The output is coming out of the wrong side of the headphones (i.e., suppose to present sounds on left, comes out on right headphone)
You will need to reinstall the drivers
If that doesn't work...you will need software that allows you to invert the sound.
Please rate if this helps!
Mar 03, 2011 | Edirol UA-1EX USB Audio Interface
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
No midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Sep 21, 2008 | Edirol UA-25 External Sound System
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Jan 28, 2008 | Edirol UA-4FX External Sound System
Edirol UA-101
DOWNLOAD THE LATEST EDIROL DRIVERS AND INSTALL ...
Aug 19, 2006 | Edirol UA-101 External Sound System
Edirol UA-101 External Sound System Logo
257 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
