Teac x-300 not playing
I have just bought a second hand Teac x-300 pro reel to reel tape machine & not sure how to work it yet, I have just bought 7" reel tape for it, fitted 2 of them on. When I press play nothing happens, do you know why this is ? Ive also enquired about buying a main drive belt for it but it would be very helpful if I could get the manual, do you know anywhere to get a manual from ? Thanks. Glen.
  • GQUEST Nov 30, 2007
    Thanks for your reply accordianman, I'm not sure exactly how to thread the tape, but I'll give it a try & let you know how it goes.
  • qdl225 Jul 23, 2008
    I do not know how ? to thread my teac x - 300, so it will play !!!!!
SOURCE:
  • 277 Answers
SOURCE: Teac X-10 connections to a dbx 224
connect the x10 outputs to the dbx 224 line in connect the dbx 224 outputs to the cd recorder anlog line in windman
Posted on Jan 31, 2006
SOURCE: Main drive belt
One of your tapes has gone bad. It may be knotted up inside the cartridge, so that it works for a short time before becoming to difficult for the drive to spin, popping the belt - or the belt may pop seconds after you insert it. To fix this, put the belt back on and then insert each of your tapes until you find the one that pops the belt (or just sounds obviously difficult for your drive to spin), and remove it from rotation.
Btw - I'm a field engineer for a tech company that services about 800 customers on the east cost - I see (and fix) this problem, with this drive about once a day.
Posted on Feb 27, 2008
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it [email protected]
Posted on Jun 20, 2008
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
I picked up a reel to reel deck to play tapes that are about 30 years old. It plays fine, but I noticed the take up reel is about 75% full, but the play reel has about 40%, so it won't fit. Thoughts?
Logically, if the full tape reel and the empty reel are identical the second must fill at the same rate the other empties and all the tape from the first will fit on the second.
What does happen, however, is at the start the second reel seems to fill much quicker than the first reel is emptying, which is understandable when for any given tape length the second reel will revolve between at least twice as fast as the first reel and probably even faster.
A tape reel that appears to be half full will have much less than half the available tape capacity filled.
Sep 02, 2018 | Teac Audio Players & Recorders
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
FF problem on Teac Reel to Reel
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old.
I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
Jul 15, 2013 | Teac Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
Right channel on TEAC 4070G, 7" reel, is making
my god its 2011 its time you got a new one my friend, usb is much faster smaller and easier and better sound repro, do you still wear flares :)
Jan 24, 2011 | Teac Audio Players & Recorders
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
TEAC 2000R SITTING FOR WHILE NOW WILLNOT PLAY
This sounds like the solonoids are not working. This can be a power supply problem, a control problem, or the solonoids themselves. In any case, this will need to see a service shop. Where are you located?
Dan
Aug 16, 2009 | Teac Audio Players & Recorders
Hi jvanheul
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Nov 24, 2007 | Audio Players & Recorders
Open Questions:
Computers & Internet Logo
320 people viewed this question
Ekse
Alun Cox
