Question about Linksys Wireless-G Broadband Router
Where do i find the network key?
I have a linksys wireless-g broadband router connected to my pc. on my lap i have a linksys wireless-g notebook adapter model wpc54g.
  • Anonymous Dec 03, 2007
    cannot find the network key
  • 98 Answers
You can find the network key (wep key) on the web interface of your Linksys router (192.168.1.1), under the Wireless tab, look on Wireless Security.
Posted on Nov 28, 2007
SOURCE:
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
I just bought my new Cisco Linksys E1000 WirelessN Broadband router, set up the brand new cat 5 wires and hooked it to my modem. My old lap top is able to see the wireless network but my alienware lap top...
if you're running windows 7 sometimes it tries to auto detect the type of network but doesn't ask for a password, when it starts to try to auto detect hit cancel and enter in the password manually.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Dec 31, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Hi do you know how I can connect my lap top to the internet wireless with my linksys wireless router ? the lap top asks for an access code and I do not know what it is or how to find it do you know how to...
The access code or password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop/computer to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 27, 2010 | Linksys Wireless-G Broadband Router
Connectingmy laptop towrt54glinsky
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Mar 27, 2010 | Linksys Wireless-G Broadband Router
I tried to secure my Linksys Wireless-G Broadband Router last night and set it up to require a password by going to 192.168.1.1. I also did something(I can't remember what) on the linksys website that made...
When configure security, is better to connect to network cable. Because once u setup the wireless key such as WEP or WPA, u will be log out from the wireless connection and u need the correct key to login.
Feb 26, 2009 | Linksys Wireless-G Broadband Router
I cannot connect a new lap top to our wireless router
There's no special settings actually in adding another notebook to your wireless network. You can add up to 32 wireless clients on your wireless network. You will see a wireless network icon at the system tray by the clock, just click that and you will see the list of available networks. Choose your network and click connect. That should do it.
Nov 30, 2008 | Linksys Wireless-G Broadband Router
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Nov 07, 2008 | Linksys Wireless-G WRT54G Router
Secure internet connection
To secure a wireless network connection, either WEP or PSK has to be enable in the LinkSys router and a passkey designated/chose. This passkey must then be likewise encoded into your HP notebook wireless networking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Laptop setup
just connect the linksys router to wireless router and just install the setup cd given with wireless router ..after configuring your laptop just insert the cd in another laptop and copy WEP key in it and get connected through wireless network
Jun 19, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
228 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
