Question about Tvone Scan Converter with Graphics (cs450) Scan Convertor
No tv manual
I bought a second hand Philips tv. It has Trendset, FSQ Vision, TXT computer controlled written on it. I have a remote that came with it it has Digital Remote Control RC 5536 written on it. I dont know how to use all the buttons on the TV. I was trying to find a user manual on the net, but to no avail. Hope you can help.
Donna
My email address is [email protected]
4 Suggested Answers
SOURCE:
murdoc1110
  • 37 Answers
SOURCE: My Maganasonic TV MT 5524, it does not function
If the remote has never worked, replace the batteries, then you may have to check the programming code (which is abundant on the internet). If it USED to work, but doesn't anymore, you or someone/something else ma have pushed the "DVD", "STB", or "AUX" button. Push the "TV" button and give it a shot.
Posted on Oct 04, 2009
  • 8457 Answers
SOURCE: I need to know how to adjust the pitcher on my
Try website like Remotes.com to buy the original remote.Use the remote to to do the colors adjustment.
Posted on Jun 10, 2010
budmrtn
  • 11361 Answers
SOURCE: remote will not turn on tv or control volume
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Posted on Jul 14, 2010
Goodmans gtvl26w17hdf
first and foremost,do you know how to operate your universal remote control?refer to it`s manual...look for that unit`s brand if it is also included to the unit that this remote control can command.if it included,look for the codes below it and try to follow the steps/methode of using this codes.example;:; 1-press the search button for 3 seconds until the led stop blinking or start to blink 2-press the unit(tv`s,dvd,ref,a/c,etc...) 3-put the 3 or 4 codes ,4- etc....
Jan 31, 2014 | Televison & Video
Need need the code for philips TV for my All in One remote OARPO5S
028,025,022,023,029. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 03, 2013 | Philips PM435S Remote Control
I just bought a Philips Universal remote control,and I have an older Sony TV. I was going to call for directionson how to install this remote to make it work on this TV. How do I set it up? I prefer...
Hi Earle.
Using a Philips Universal remote is very simple. Since there are different remotes we would need the exact model of the remote. This is usually written at the back of your Philips remote.
About voice talking, I am not sure that the phone support service is still active. You can check on Fixya page.
Please try giving us the remote number, and we will see if it is possible to help you with your problem online.
Regards.
Ginko
May 26, 2011 | Philips Televison & Video
Tv code
The Innovage Jumbo remote control manual does not list any TV's by the manufacturer Vision Quest, but that does not mean your TV is not compatible with another brand's control codes. I recommend using the auto-search function to see if any of the remote's TV codes work with your set.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 07, 2009 | Innovage Jumbo Remote Control
I can't see my tv
You likely need to select channel three or four on the TV itself if you have any kind of box between you and the signal source (cable, antenna, satellite). Magnavox is a name owned previously by Philips and now by Funai. They may not have all the info from Magnavox and Philips but you could check their website to see if they have the instruction manual for download.
Look under 'Support'
Funai
Jan 20, 2009 | Philips E-Box FTR9965 DTV Receiver
Need codes for ct 90157 remote for phillips dvd player.
I'm not sure if you can use it for a DVD player, every place I look says it's TV only. Odd, since it has a TV/Video button?!?!?
But here are the newest Philips codes:
Philips 006,007,010,011
,013,016,033,035
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Toshiba CT-90157 Remote Control
Bt vision remote
www.remotecodelist.com .....................................T.
Mar 20, 2008 | Televison & Video
Lost manual...need to program new tv...
The manual shows it is one of these codes for Philips TVs: Philips.................................................................................................................003, 004, 006, 008, 062, 068, 069, 074, 075, 086, 087, 089, .......................................................................................................................................................163, 183, 184, 205, 206, 207, 208, 212, 213
Sep 03, 2007 | RCA 9-Component Remote Control with LCD...
Tvone Scan Converter with Graphics (cs450) Scan Convertor Logo
299 people viewed this question
Top Tvone Televison & Video Experts
Jaime Hernandez
Ekse
Falling star
Are you a Tvone Televison and Video Expert? Answer questions, earn points and help others
