This is for a 2.0L Engine
for a 2.5L engine
4.label and disconnect the wiring at the starter.
5. remove the starter mounting bolts and remove the starter.
Instalation for both are the reverse of the removal.
SOURCE: how to replace starter
Keep in mind that the engine sits in there sideways, so the "back" of the engine, or flywheel is actually on the driver's side (the front is on the passenger side). The starter for any vehicle is at the flywheel. Raise the vehicle and crawl underneath from the front on the driver's side. Look for the oil filter. Slightly above and to your left (toward the driver's side wheel well) is the starter. It looks to me like you'll need to drain the motor oil and remove the oil filter to have room to remove the starter.
SOURCE: how do i remove the starter motor on my 97 mazda
1. unplug the connector
2. unbolt the wire coming from the battery
3. remove the two bolts holding the starter on the engine
don't forget to unplug the battery!!!
SOURCE: How to remove drive axles
the lower ball joint has to be undone.cotter pin and castle nut
the axle nut 36mm has to be undone.
.the control arm swung away from the end of the axle shaft.
using a pry bar,pry the knuckle away from the transmission,as just pulling out will not release it.
installation is done by lining up the shaft in the transmission and using wood or a brass drift to hit the shaft to seat it in place.
the lower conrol arm is a little tricky to move so that the hub fits over the axle .on average about 50 lbs force is needed to move it out of the way.
be sure to replace the cotter pin with the head fully inserted into the castle nut slot.
cheers and good luck.if you run into problems,get a haynes manual,it clearly explains and has pictures,and then you have a service book for your car.
SOURCE: 1992 mazda 626 = not getting fuel,will start while
fuel filter should be located under the hood on the driver side below the brake master cylinder, fuel pump is in the tank some vehicles you can lift the rear seat bottom and get to pump others you have to drop the tank and remove the pump.
Testimonial: "thx,there was fuel on both sides of the fuel filter.i lifted the seat , removed the access pannel & it's getting power.i don't know how to remove it."
SOURCE: 1992 mazda 626 where is the obd conector located
your connector is under the hood on the passenger inner fender well back by fire wall
