Question about Motorola Mobility RAZR V3
Motorazar V3xx Broken glass on external display! Can I find just the replacement glass and put it in myself?
  • arumononline May 19, 2008
    I have a Motorazr v3 and the outer display glass got cracked..what to do? can I replace it. Can you please send me the address of any authorized Motorola Service centers in Kolkata?
  • 30 Answers
Yes!, ebay.
Posted on Nov 29, 2007
SOURCE:
Can I replace the glass on my french door myself? My doors have miniblinds in between the panes.
You need to have a glass shop replace the broken pane because the original one was vacuum sealed and unless you are able to do that then the window is going to cloud over once it is back together. Now if you just want to replace the broken pane and not seal it then you can have the glass cut to size and just install it.
Jun 04, 2015 | Refrigerators
My motorazar v3 xx don't charge when it is in my laptop an i want to solve this problem immediately how do i do this
Hi
There's a driver that you need to download and install in your laptop so it will charge from it. click HERE and download the software driver and check if its compatible with your operating system by checking system requirements.
Hope this helps
Apr 02, 2010 | Motorola Mobility RAZR v3xx Cell Phone
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 | Ovens
....motorola v3xx won;t turned ON!!..HELP
Have you tried replacing the battery? Also try this first - remov battery and SIM card. Wait 1 minute. Replace battery and SIM and power on. See if that helps.
If problem persists, you may have to repair the phone.
Oct 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Broken screen
if it is limited to external glass the glass can be ordered separately but if there is internal crack on pdp itself would have to replace pdp. from my experience generally if it limited to crack on external glass there still should be picture so there may be additional damage to plasma display itself
Aug 16, 2008 | Philips BDS 4611 46 in. Plasma Television
Garmin c330 fell and the outside glass to screen is not broken but the layer under it is shattered. it powers up but touch screen does not respond. is this something i can fix myself?
No, you will need to replace the LCD screen. Unfortunately, Garmin will charge you almost the price of a new unit for fixing it. You might be able to find a used unit on eBay that is dead but has a working display and swap the displays but it requires some electrical & mechanical knowledge.
If I can find a display, I can put it in for you for a reasonable price.
Please let me know if I can be of further assistance to you.
- Jim
Jul 12, 2008 | Garmin GPS
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
V3xx signal loss
take the phone to a mobile service shop and have them replaced the antenna that is located on the phone's main-board.
May 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
External antenna
try teking the phone and have the antenna replaced or service that should correct any problems that you may have.
Feb 01, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Where would they hide?
you can try this web site they say they have em http://formymobile.co.uk/proddetail.php?prod=v3lcd
hope this helps you.
riz.
Nov 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
