Question about Toshiba Satellite A100-S8111TD Notebook
Won't power up
Checked the charger.charger is ok laptop won't even show up a light nothing, no power????????Is there a reset???or is it somthing serious.
  • Anonymous Nov 28, 2007
    I accidently dropped my computor, it does boot up but the mains light is on all the time and if I plug the charger on, it makes no difference(don't think its charging. Could it simply be the battery damaged????
  • Taylorck2 Dec 26, 2007
    I'm having the same problem with my A105-S361. Power supply doesn't seem to be working because nothing lights up when plugged in (I think a charge light came on when plugged in before). This is odd because I just replaced the ac adapter about 6 months ago. I'm reluctant to spend $80 on another if it's possible it isn't the power supply. Any suggestions as to how to troubleshoot this?
    Scholar:
  • 181 Answers
Well, these models are known to have weak solder joints where the power adapter plugs in to the laptop.
It's possible the socket has come undone from the motherboard.
Repairable. Toshiba might even extend warrant on it as they have in the past.
Based on the info you have furnished, it's an 80% chance that's what it is.
Let me know, the board can be repaired in most cases.
good luck
Posted on Nov 28, 2007
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Acer emachine s525.it will not power on,it refuses to charge.the charger lights up but nothing.I have tried using a different charger for another laptop it also shows that there's current coming...
The AC jack may be damaged due to pulling on the cord. Make sure the other cord/charger/transformer is the EXACT same power spec before plugging in, it may fry the laptops internal PSU.
Jan 15, 2013 | Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
I have a Dell Precision M60 laptop and the charger adapter's led light is on when i plug it in, but the laptop won't turn on.I've replaced the battery and tried a different charger but that...
Unfortunately it sounds like you have an issue with your motherboard. If you remove the battery and just try to power on the laptop using the AC adapter and it still won't power on then it's probably the motherboard. The power supply circuit (where the AC adapter plugs into) for the motherboard is integrated into the motherboard.
Sorry. If it's still under warranty Dell will replace the motherboard.
Sep 10, 2011 | Dell Precision M60 Notebook
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
