TV Volume settings
Hi, Is there any way to adjust the actual level that the volume is on certain settings on the Grundig Xentia 32 LCD TV? We find that level '9' is too quiet but level '10' is too loud, and wonder if we can reduce 10 a little or make 9 a bit louder..
  • 1,284 Answers
These are all settings that are put in by the factory and cannot be changed.
Posted on Nov 30, 2007
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Sharp LCD TV ad volume higher than program volume
It is a problem of the transmission of that particular channel or your channel provider. If this problem is common to all channels, complaint it to your service provider. Else complaint it to the responsible channel (Not actually necessary as others might have done it and they might be already trying for the fix). This is not a problem of your television set and need not worry about that.
Apr 17, 2010 | Sharp LC-32AV22U 32 in. LCD TV
My volume on my sony tv wont go past 12 it will higher and lower but the maximum it will higher to is 12 have i maybe put a volume lock on it??
The only way the volume could be limited is if you were in the hidden tech menu----many of these sets have a setting there for initial volume level and maximum volume level.
Were you in the TECH menu for some reason?
I can tell you how to get in but you have to be very careful if you make any ADJUSTMENTS there--over 200 things can be adjusted there.
Let me know if I can help.
Feb 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Sansui 21in LCD VOLUME is lowering
If you are using a set-top box for Digital reception....check the output volume setting by going to the menu then audio set up section. On standard TV transmisssions the sound is often fine but on Digital....the box sets the feeder audio signal level.
Jun 29, 2009 | Sansui HDLCD3210 32 in. LCD TV
32LG30 television, volume too high from level 0 to 1
If you are using a cable box...turn down the sound on the cable box.
Jun 24, 2009 | LG 32LG30 32 in. LCD HDTV
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Televison & Video Logo
353 people viewed this question
Top Televison & Video Experts
