Back to:
Tags:
Nikon COOLPIX L3 Digital Camera
It wont turn on
posted by rpm53 on Nov 28, 2007
my camera will not turn on despite putting new batteries in...nothing has happened to it
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 25, 2008
Not Rated (0)
dlundmark
Rank:Wiz Wiz
Rating: 81%, 70 votes
Sometimes we cannot solve a problem.
Seems you have come to the end, if that is the case.
So, my suggestion...sell it on a site such as Ebay for parts, repair, or as is.
take care,
Comment by dlundmark, posted on Jul 26, 2008
Something I thought of is:
Check the battery door and also the card door (if there is one separate) for a small plastic "pin" or raised area, usually located on the door to activate a small switch to let the camera start. If the small "pin" or raised area is broken off, then the camera will not start. If this is the case, you can put something over (small enough) the switch and when the door is closed it will let the camera start and run. On one camera I used a very short piece of solder and some scotch tape..... The best in such a case is to replace the door (if you have the time and patience to do such a repair) or sell it for repair or parts.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on it wont turn on:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
Digital Cameras
I have a Nikon Fe and the shutter isn't releasing....
Uselesss view finder - can't see outdoors
1. What does a red blinking hand in right corner of screen...
the camera lets me review pics but the lens doesn't come...
describe your problem in detail. if you are not...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
