Question about Toshiba Satellite P25-S5263 Notebook
Psp need browser password
    President:
  • Toshiba Master
  • 2,022 Answers
Pls write your problem in detail.
bye
Posted on Nov 30, 2007
What i need to do to connect my psp for internet
You will need a wireless router in order to connect the PSP to the internet
  • With your Psp turned on go to the "Settings" in the menu (scroll to the left)
  • Scroll all the way down until you have reached "Network Settings" and click the "X" button to enter
  • Select "Infrastructure Mode" and hit "X"
  • Select "New Connection" and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose "Scan" and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • When the PSP finishes scanning you will probably have a few different wifi connections. SSID is the name of the connection, the Security column tells you whether or not the connection is password protected, and the last one is the signal strength the higher the better
  • If you want to borrow your neighbors unprotected wifi select a connection with "None" in the security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • Now the Psp will confirm your settings proceed by pressing left on the d-pad and save your settings
  • Now test your connection if you are able to connect, awesome. If you were not able to connect try doing the settings again
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached "Network" and go down to "Internet Browser" and hit "X"
  • Your browser will appear, select the little square box to enter the web address, play around with the different options. Have fun with your PSP online
Dec 16, 2010 | Sony PlayStation Portable (PSP) Console
My psp wont connect to my router and i have the same wep key password in is this a "firewall" problem?
What exactly message you get when u try to connect your PSP. However, here is simple few steps to configure your PSP, just see if u have missed something. (Router Configuration) open your browser and type 192.168.1.1 and use admin as username and password.Apply your PSP MAC in the routers. for this go to Parameters > System> PSP Information in your browser of PSP. (PSP Configuration) Go to Settings >LAN>Infrastructure Mode>New Connection>Scan> now select the IP address of the Router and enter the WEP key which is written the router. Now you should be able to do Custom>Automatic>Do not use . Remeber you only select Do not USe if you dont browse through your PSP. Now Enter and this will InshahAllah solve your problem.
Regards
Jun 09, 2010 | Actiontec GT704WG Wireless Router...
How can i connect my sony psp online
Turn on your WLAN switch....
Go to Internet Browser....
Network Connection> [New Connection]> Scan> now *select an access point*,> *now check the info*...; SSID>WLAN Security Setting>net password (if required)> Address Settings; Custom> IP Address Setting; Automatic>DNS Setting;Automatic> Proxy Server;Do Not Use(your choice)> Internet Browser; Start>Enter the connection name; (your choice)>Setting List; *scroll through to see if the info are correct*> Press the O/X button to save settings.
Select connection....... DONE!
Oct 22, 2009 | Sony PlayStation Portable (PSP) Slim...
Dont no how to connect the internet to a psp go
  • With your Psp turned on go to the “Settings” in the menu (scroll to the left)
  • Scroll all the way down until you have reached “Network Settings” and click the “X” button to enter
  • Select “Infrastructure Mode” and hit “X”
  • Select “New Connection” and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose “Scan” and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • If you want to borrow your neighbors unprotected wifi select a connection with “None” in the Security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached “Network” and go down to “Internet Browser” and hit “X”
T my WEP key is there a way I can find it
Hi!
WEP consists of 10 number and letters and is usually under your Wi-Fi (wireless) router...enter that code into ur PSP and it will grant u access to the internet.
Or type 192.168.1.1 or 192.168.0.1(which ever your router has set to access it) into your web browser and your loginour password is usually admin and Password is usually blank (as in don't type anything in it) for your router will pop up from there you can find your wep key or you can turn the wep off so your psp will not need a wep key.
Please rate this solution.
Thanks
Rylee
Feb 14, 2009 | Sony PlayStation Portable (PSP) Console
I need to now how use my psp san disk and can get on websites
For you to surf the internet, your PSP has to have firmware 2.0 and above. to find out what firmware your PSP has:
1. Turn on the PSP.
2. Go to the "Settings" category (it's the one farthest to the left).
3. Scroll down to the "System Settings" icon and press x.
4. Scroll down to "System Information" and press x.
5. The screen will display the PSP's MAC Address, System Software Version, and Nickname. The
"System Software Version" is the firmware version.
If you have the 2.0 And above firmware heres how to get connected to the internet :
  1. Find a wireless access point. make sure you have the correct password as you will be asked to input it in order to connect to the WAP.
  2. Insert a Memory Stick. If you want to save any bookmarks while you're online, you'll need to have a Memory Stick to save them on. The same goes for any content you might want to download.
  3. Turn on the WLAN switch. You'll find this on the left side of the PSP, just above the Memory Stick slot.
  4. Set up the Network Settings. You'll find these under the "Settings" menu, right at the bottom of the list. Choose "Infrastructure Mode" and follow the instructions. Here's where you might need a password (see step 1).
  5. Open the Browser. Select "Network" from the home menu (it's the one farthest to the right). Scroll down and select "Internet Browser" (the icon has www on it). The PSP will connect and the browser will open (there will be a slight delay as this happens).
  6. Go to the Address Bar. If you don't see an address bar at the top of the browser, press the triangle button and it will appear. Navigate to the address bar using the up button on the d-pad. The address bar will light up.
  7. Surf away !
and in the case of you talking about San Disc. im guessing your asking how to insert and your Memory stick Duo? if so follow these steps :
  1. Open the slot cover for the Memory Stick Duo located on the left side of the PSP? system.
  2. With the printed side of the Memory Stick Duo facing out towards you, slide the Memory Stick Duo? into the slot in the direction of the arrow printed on the Memory Stick Duo.
  3. Press the Memory Stick Duo until fully inserted.
  4. Slide the slot cover back into its original position
Hope this helps !?
Oct 25, 2008 | Sony PlayStation Portable (PSP) Console
How to enter your IP Address on psp and were is my WEP key
PC:
Go to your web browser
Type 192.168.1.1
Its gon ask u for a username an password
Default username: admin Password: {blank} or password
go to wirelesssettings and u should fin ur key
Sep 15, 2008 | Sony PlayStation Portable (PSP) Console
Hi mate
Through Wi-Fi, go to a Wi-Fi zone and I hope it is free. Turn on your PSP, go to Internet Browser, Scan, select an Access Point, press Right Button a few times and hope it is not password protected. Save the settings. Select it when you open your internet browser again.
May 05, 2008 | Sony PlayStation Portable (PSP) Console
Psp internet problem
Ok, this problem has happened to me before, and most commonly the problem relies on a wrong inputed password on your psp. Double check the password you put into the psp is the same one you have for your entire network. If you are continuing to have problems try unplugging the modem and router for about 15 second and connect them again. Good Luck!
Jan 19, 2008 | Sony PlayStation Portable (PSP) Console
How to get internet on my psp
Look its not necessary get internet on ur psp. Its how to connect to the internet on the psp. You are gonna need a wireless internet network. Usually at food restaurants, or at ur house. Its not like you can connect the psp with a cable to the internet. Its all wireless hottie262477. To find wireless go all the way to your left on the psp and turn on the wifi button. Then go ur settings and all the way down to network settings. From there click on infracture mode. And scan for wireless hotspots. Of course any wireless one that says it needs a wep code. Means that it has a password and if you don't know the password you can't necessarily access it. So use the no password hotspots. Also remember its very easy to connect a wireless network in your house as long as u have high speed internet. Now that you this u can enjoy ur psp and play online and use the web browser. Good luck Diego :-)
Jan 13, 2008 | Sony PlayStation Portable (PSP) Console
Toshiba Satellite P25-S5263 Notebook Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
