Question about M-Audio DX4 Active Studio Monitors (Pair) Computer Speakers
Studio monitor chaos
Hi
i just bought some krk v4 studio monitors and i can hear major computer noise coming out of them. man, i have tried everything to fix it i will list.
tried balanced and unbalanced leads, xlr's with ground lift connections, new planet waves gold plated usb cord, tried taking out my usb mouse, tried different powerpoints in the house for computer and speakers. yesterday i took the whole setup to a music shop and tried a different interface and it stopped it, so i thought fine, must be a dodgey interface. Also while i was there i tried the speakers running out of the phones jack on the computer with a splitter lead. it was fine.
So i get home, buy a new splitter lead and just run it out of the computer and bang there it is again. mouse noise, computer noises, everything!
The last thing i will mention is that when i run the laptop on battery and not the powerpack it stops, but every now and then i can here interference.
It appears to me the problem is in the computer or powerpack but i tell you its driving me nuts trying to figure it out. i really dont have a clue whats going on.
the laptop i have is brand new acer aspire 5760 and the speakers i was previously using were not making the noise although when i cranked it right up full i can hear the exact same stuff going on, just no where near as loud. these speakers were not powered just running out of the phones jack into an amp.
the last resort i can think of is have the computer powerpack checked and the computer checked.
I was really hoping you would know exactly what it is cause im at a loss.
Hope you can help
Deon
    New Friend:
Hey buddy, this is a common issue with laptops and professional audio equipment, if your laptop is grounded when you plug it in (third prong on your plug or asymmetrical prongs like in Canada), the electrical signal running through your computer will become very dirty and affect your audio signal, even if like me you use external ASIO sound-cards. My solution to the problem was to cut the third prong with a pair of pliers, as I use my computer to DJ, and the interference was too much to bare on large club sound systems. I do not however recommend you do this.
Posted on Apr 22, 2011
  • 51 Answers
Please change your probes or change your volume control knob as quickly as possible because it has been got damaged...
Thank you...
Posted on Jan 04, 2008
SOURCE:
Hi my names jason and i have a crackling problem with one of my krk rokit 5 g2 played a few tune's and the one speaker won't stop poping please could you help me with this i don't...
Try swapping the monitors inputs. if the other speaker starts popping on the same output it'll show that the mixer may have a problem. otherwise return for repair.below is a link to the manual. check out the troubleshooting section pg 13
http://www.krksys.com/manuals/rokit/rpg2_manual.pdf
Sep 12, 2011 | KRK Rp5 Rokit 5 G2 Studio Monitors Rp5g2...
I need to remove one power amp module from an older KRK Expose E8. The obvious screws have been removed but the module still feels firmly attached to the cabinet. Is there something that I am missing?
Hello
If you have unscrewed all the seating screws of the circuit board, pull out three knobs at the rear side [HF SHELF/SYSTEM LEVEL ADJUST/HF LEVE ADJUST] and rings screwed to the switches of LF Level adjust, and the screws of XLR socket. Amp with its seating frame wcan be pulled out.
For further details log on to
www.krksys.com/krk-studio-monitor-speakers/expose.html
OK.
Apr 12, 2011 | KRK E8B EXPOSE
Hi, My Dell Studio 1735 Laptop doesnot display anything, i hear sounds of it getting rebooted and startedup but, wont display anything. I tried conencting to external monitor NO...
The video card most likely has failed. The computer will need to be serviced by a trained technician. The entire motherboard will need to be replaced.
Feb 28, 2011 | Dell STUDIO 1735 Motherboard - H274K
My GEM GL-1821A Computer monitor has a high pitch squeak that is intermittent in occurrence but sometimes continues for long periods of time. Got any ideas?
A high-pitch squeal is common in CRT TV sets and monitors. I've never run across this in an LCD monitor, but there's a first time for everything. If the sound isn't coming through built-in speakers (if this model has them) and is being caused by the computer, I would suspect the inverter circuitry. This provides power for the backlight, and there are transformers that may have become noisy. Because of their construction, it's possible for them to vibrate internally, and at a frequency that you hear as the high-pitched noise. There isn't a lot you can do to quiet them. When I worked on TV sets, I had mixed success using hot-melt glue to muffle the noise, but usually the only way to completely cure the problem was to replace the parts. It's unlikely you'll find the parts available for a monitor, so all I can suggest is to bear with the noise as long as the monitor is otherwise working properly. Or use this as an excuse to buy a new LCD monitor; they are quite reasonably priced these days.
Feb 16, 2011 | Think Computer GEM 15 Inch LCD BLACK...
I cannot get any sound from my ViewSonic VA1912wb Monitor. I have everything plugged in the mute turned off showing 100% volume the green jack in back of monitor and green match on computer. No sound from...
You may need to load the monitor drivers.
I assume your PC sound is OK.
When you are plugging the green lead in the Moniotr / PC do you hear any noise from the monitor?? if not may be faulty.
Try plugging a friends set of speakers into the back of your PC.
Mar 09, 2010 | ViewSonic VA1912wb Monitor
I have a KRK Rokit Powered 5 studio monitor and the fuse blew out, so i replace the fuse with the spare they provide and ''bam'' blows again as soon as i turn on the monitor. i have had these for about 4...
Look for a failure in the power supply section. You will need electronic experience or someone who has that.
If the fuse is glass and blows silvery inside thia means a direct short inside. SUSPECT the input rectifier or filter capacitor(s).
Do testing with a 100 watt light bulb in series with the hot side of the power cord to avoid blowing fuses.
Oct 10, 2009 | Music
Hi im raja from pakistan ... i hav monitor of LG studio works model 710 ..im getting display problem some time its come and some its not...even the HT volts r proper
check the power cables of the monitor. if everything is perfect then there is a problem in your display card..
Thank you......
Jan 29, 2009 | Computers & Internet
No sound coming through speakers from microphone
ok i have windows vista so u have to right click on sound icon speaker then click playback n select conexant high definition smartaudio 221 n right click it as default n u gotta re load up acid then right click n insert audio
Dec 14, 2008 | Sony Acid Music Studio 7 Full Version for...
M-Audio DX4 Active Studio Monitors (Pair) Computer Speakers Logo
243 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Don Hart
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
