Question about Matsonic MS9158E+ Motherboard
Ram slot why my motherboard cannot put 2 slot RAM? if i put double RAM128. It stil run RAM 96 only. please help me
  • Anonymous Apr 28, 2008
    I put a 512MB PC400 Ram on my computer but it reflects 256MB what can be the problem.
    Champion:
  • 209 Answers
The problem is probably the 2 ram have different specifications. what i mean is that if one ram is PC400 and the other is PC333 there will be a conflict. you should install the same specs and with the same cast latency timer.
Posted on Nov 28, 2007
Fdmdgo-03014s
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
Nov 26, 2012 | Chaintech 9BIA (CT-9BIA) Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Asus P4B533 gives single beep at boot after installing Corsair 1GB PC2100 double sided ram in slot 1 by itself. No problem when 2 Kingston 256 MB single sided in slots 1&2.
These motherboards, as with most manufacturers, seem to have preferences for specific makes/models of peripheral gear, especially for RAM chips. Consult your motherboard manual for compatible RAM, and proper placement in the RAM slots. Also, consult the motherboard vendor for info in this regard. They may have specific experience with this motherboard that can steer you toward the proper RAM to use. ie, it is in their interests to have satisfied customers for repeat business, by supplying peripheral items that function reliably with the motherboards they sell. Don't delay, since this technology, and the items that stores carry change at an ever-faster pace. Also, don't cheap out by using RAM of questionable fit for this motherboard.
Please feel free to get back to me about your situation.
Oct 27, 2010 | ASUS P4B533-E (P4B533-E/L/1394)...
Has pc100 128mb and tried to go to Pc133 and wouldn't accept, what is the max memory i can put on this board
the details of that board are sorta sketchy, it could be an intel 810 series or 815 series. theres really no way to tell except by opening it up and looking for the largest exposed ic chip with intel stamped on it, and look for an 810 or 815 designation on that chip.
if its an 810, it may not support pc133 ram, depending on the exact 810 model. if its an 810, it also will not support more than 256 total ram.
if its an 815, it will accept 512 total ram, if not more; however, you will have to go with no more than 4 ram sides- meaning, if you have 2 double-sided ram sticks, you will not be able to add anymore. if you have 2 single sided sticks, and a 3rd ram slot open, you may be able to add a double sided stick in the empty slot for 1+1+2=4 ram sides.
Sep 29, 2010 | Gateway PGA370 E139761 DIMM Motherboard...
Nforce4-a939 board ,my system shows single channel 64 bit but on perchasing it was dual channel 128 bit how can i fix it......
The 128-bit mode is achieved by putting _matching_ sticks of RAM in the RAM-slots. Non-matching RAM will run as "single-channel" (64-bit) mode.
Matching RAM must have the _same_ amount of RAM per stick,
and the same internal "timing" parameters (look closely at the RAM for strings like 3-2-2 or 2-2-2-2).
If you have exactly 2 RAM slots on the motherboard, matching RAM will always run in "dual" mode.
If you have matching RAM, and you have 4 RAM slots, put one stick of RAM in slot #1, and one in slot #2, and leave #3 and #4 empty. Start it up, to see if it is using "dual" mode.
If not, shutdown, power-off, and move the RAM from slot #2 to #3, and start it again. This time, it will run in "dual" mode.
Jul 21, 2010 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
I ran diagnostics on my Dell Inspiron 1525. Results: Data Bus stress test failed. Memory compare error, DIMM-B. Suggestion: try to reseat the memory. How should I do? Please help! Thanks T.Doan
1. reseat the ram
2. at the buttom part of the laptop you will see a window covered which will allow you to remove and have the ram be reseated.
3. take out 1 ram firs then run test then run again the test using the other slot. please test each ram on each slot. check if the faulty if the ram or either of the rams of one of the slots. if both ram passed on one of the slots means that ram is ok and slot is not, so then replace the motherboard. if one ram errors on a slot which the ram passed then that ram might be faulty and needs replacement.
Oct 15, 2009 | Dell Inspiron 1525 Notebook
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
My msi vis p4m800 motherboard don't support two ram
Hi, does your board have 2 diferent color RAM slots?
if it does you must install the RAM in the same color slots.
If not then you have the option of buying a 512 stick of RAM and installing that as a quick fix. The other alternative is to have your board tested by a technician.
Regards mistyman
Oct 15, 2007 | MSI KT4V (MS-6712) Motherboard
Matsonic MS9158E+ Motherboard Logo
70 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
