Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Philips 51pw9363 When I turn the set on and there is a red double vision effect. It is more distorted in the upper corners then in the middle of the picture. I removed the back and covered the red flood light and the distortion goes away (but so does the red color). When I bring up the convergence cross hairs they will not vertically but they will move horizontally. Ive tried to fiddle with it but I am no expert. Any ideas? Thank you
  • 934 Answers
Jessecool,
The convergence amps need to be replaced.. Your set uses two STK392-120 Sanyo original Ics.. Also all the low ohm resistors in that circuit should be measured for change in value and replaced if not within tolerance..
Bill
Posted on Nov 28, 2007
Showing double picture
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 19, 2010 | Philips 51PW9363 51" Rear Projection...
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Seems like a line across the screen picture looks like it is smashed and sound is fine
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
Feb 08, 2010 | Philips 51PW9363 51" Rear Projection...
Philips tv #51PW9363 turns itself off and on over and over.....
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Philips 51PW9363 51" Rear Projection...
My Philips 51PW9363 has pink and green colors only!!!!
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
Jan 05, 2009 | Philips 51PP9200D Television
Mitsubishi 52 in, pic distorted, with red and green double vision effect
need to change the convergence ics you can get replacements at the following link with free instructions.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Televison & Video
Tv is a little distorted and double vision and off coloring wavy design in upper left corner
need the model number of your set it sounds like the convergence ICs need replacing. Please reply to this same post with your model number and I will post the correct ICs for your model.
Aug 07, 2008 | Televison & Video
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Red convergerce not working
there is an auto restore option on the onscreen menu its sort of hidden you need to scroll down all the way to the bottom past the multipoint options give that a try
Nov 09, 2007 | Philips 51PW9363 51" Rear Projection...
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
