Question about Weather King 12AJA4801AH Air Conditioner
Weather King AC/Heat Pump - Electric unit, Model 14AHJ11S01C01
Ice formed inside restricting the air flow but heater was still producing warm air; main power switch was shut off (circuit breaker looking switch on the front of the unit) while we began thawing the ice. 90% of the ice is gone and air is now flowing to the rooms, but now it will not heat up / produce warm air.
This happened one other time, a year or two ago, and I know it did not require major repair but I do not know (or just can't remember) what was done then to make it start producing warmth again.
Thanks, AJ
  • JHESTER24 Sep 15, 2008
    My unit's compressor has frozen up several times too and the fan runs steady and won't shut off.
    My problem is with the cooling though.
    The heat was cut on to defrost the compressor so the air conditioner would start producing cool air again but cool air blows through the vents only for a few days and then warm air comes through the vents again.
  • 49 Answers
Your evap coil in your indoor unit should not develop ice in the heat mode. It sounds like your reversing valve may be stuck in the cool mode, not allowing your heat function to work. If it is cool where you are you may need to use your emergency or auxillary heat function until your problem is resolved.
Posted on Nov 28, 2007
  • 1,420 Answers
Get a technician to check the Freon charge.
Carrier fa4anf036 home heater not a car. Blows luke warm common for an electric heater?
As near as I can tell from internet information. This model is a heat pump. It transfers cold air out of the house and gets what ever warm air might be outside the house. In extreme cold weather an auxiliary electric heater should make up the difference. The filters must be clear. There is a limit what the heat pump can do in cold weather. Your electric heater may not be activating. You could try raising the thermostat. A service technician may be needed to determine why the electric heater is not working.
Jan 01, 2018 | Heating & Cooling
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
Water leaking on the floor. The unit cannot be opened to empty? What is wrong
Check to see if ice is forming inside. If so, check filter. Blocke filter restricts air flow and ice builds up on coils then melts slowly with heat from room.
Aug 05, 2013 | Kenmore Heating & Cooling
No heat working in cab
depending on outside temperature but if you in new york state and from what i have seen on the TV with the ice then place a piece of cardboard in front of the radiator to block the air flow so the engine can get warm then when weather warms up a bit check it all out by flushing the heater core and then the engine ,check thermostat is fitted and refill with antifreeze .
Jan 27, 2011 | 1996 Nissan King Cab
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
HEAT PUMP PROBLEMS
Defrost cycle is to allow frosy or ice to melt down and not restrict the output air. The thermostat is set too low and in high humidity ice forms quickly restricting the air flow. tur up the thermostat and let the room cool gradually.
May 26, 2009 | Heating & Cooling
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Filter size
Thats an A/C, what is the indoor unit model #? Does it have a filter box? If so what size? If not do how does your filters sit in the unit?
Jun 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Electric heat strip installation and wiring
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Jan 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 12AJA4801AH Air Conditioner Logo
695 people viewed this question
Top Weather King Heating & Cooling Experts
John Tripp
John Tripp
acrman404a
Level 1 Expert
Bill Long
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
