Question about Microsoft Windows 98 for PC
Window98 speed on net is very low
Sir, i have p3 system and win98 is not work correctly
    Problem Solver:
  • 9 Answers
Windows 98 can be terribly unstable after long periods of use - the best solution may be, as previously suggested, simply to back up your important information (on to a CD that you can burn or if you do not have a CD-burner, perhaps floppy discs - depending on the *amount* of data that you have) and reformat and re-install Windows 98. A rule of thumb with Windows 98 is a MAXIMUM of two-years before you need a full system re-install.
Posted on Nov 30, 2007
  • 328 Answers
Being as Windows 98 is very poorly unsupported, you may have issues with adding software and hardware as well as the net. Updates are very hard to come by. The cheapest and easiest way for you is to do a search for Windows XP on the net, you may find one for little or no cost. If that is no option for you then you can download software such as Spybot Search And Destroy to check for spyware. The issue might be deeper and require a full re install of 98. Thats why one should look at all options.
Posted on Nov 28, 2007
    Problem Solver:
  • 10 Answers
Hi, easiest solution is upgrading your win 98 to win xp, 2nd:free space on your disk drive by removing unnecessary programs or applications to free memory space...also by delting temp files n cookies in your browser...i hope this helps, please feel free to ask if you need further assistance..good luck
I have a challenger 2 speed spa pump. Only the low speed seems to work. I have back-tracked all switching. The correct voltage is getting to the correct motor terminals for low and high speed operation. I...
You are correct. Appaently you have a short in the winding connection and that is not a do-it-yourslef type of repair. Unfortunately, the cost to fix something like that is high since it is labor intensive and you may want to look into a new motor since the chances of additional or near future failures is likely. If you would like a quote on a new motor, contact us thru www.arrowmotor.net and be sure to include the voltage you are connecting to as a 1.5 HP is available in both 115 and 230VAC.
Sep 25, 2009 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
HP printer 3650 driver for window98
Sir hp printers are not supporting window 98 sinnce last two years.
If you want to work with any other operating system so download from the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=304535&lang=en&
thanks
TTYAGI
Jun 12, 2009 | HP DeskJet 3650 InkJet Printer
Pc speed low in use internat
specification sounds good, there are two possibilities caused such problem:-
over load of applications/memory resident programmes and
most probably, the system infected by virus.
un-install some not needed apllication and check system with a lattest/updated virus cleaner.
Dec 19, 2008 | Microsoft Windows Vista Ultimate Edition
A software in which winxp works without any installation
I believe the program you are looking for is called ERD Commander. It was made by Winternals and is no longer availible due to Microsoft buying them out. You may be able to find older copies still available for download on the net if you search for ERD commander or winternals.
Dec 17, 2008 | Microsoft Windows XP Professional With...
May be a bios problem
Sounds like it is a hard disk issue. Corrupted MBR. Or missing Boot Loader. Your partition must be Fat32 since Win98 won't recognize NTFS. Try running chkdsk if not successful than repartition and format. BIOS is OK since you stated it will install windows. Corrupted BIOS won't allow pc to load. From a win98 bootdisk choose not to load cd. From the dos prompt type FDISK /Status If more than 1 partition check active partition settings.
Nov 05, 2008 | Intel Motherboard
Sound device problem
you have doesn't gave me the description about your sound card. any way at please install your sound driver and direct-x 8.0 or supportable above then restart.
Aug 04, 2008 | Microsoft Windows XP Professional
Win98 booting
hi when u upgrade memory did u install same bus speed ram if not change them or check removing one by one ram from the slots. if not working than may be your os cruppted or bad caps on the motherboard. check tham all may be it help you
Mar 03, 2008 | Computers & Internet
Anti virus software for slow speed machine
freeav.com turn on security privacy risk in advanced settings
Nov 05, 2007 | Microsoft Windows 98 for PC
Modem
Hello sir,             I am using P3 computer and I am using  Win XP -Service pack-2. I am using Reliance connected CDMA WLL Phone made by ZTE Corporation for internet surfing.My problem is, for every time while I connect to internet, my modem to be reset and then only I can enter into the internet.I have made all installtions as per the service provide's instructions.I have to reinstall everytime or sometime I can't enter. whether I need any modem drivers for easy access to the internet.My phone model is CLASSIC -23. If yes which type of drivers and how to install.
Oct 13, 2007 | Computers & Internet
Microsoft Windows 98 for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
