With an assistant, release the parking brake cable tension by pulling straight back on the intermediate cable at the cable-to-cable union until the parking brake control sector (of the brake pedal) rotates to a stop. then insert a 4mm retainer pin in the parking brake control pedal to keep it from retracting on you.
Disconnect the cable running from the brake pedal to the cable-to-cable union underneath the car.
Then replace the damaged or severed cable that controls either the left or right rear parking brake shoes.
Use a test light at the contactor to see if the switch and wiring are good.If you see an input from the switch up to the contactor,make sure the connections are all clean on the control input terminals at the contactor.(The contactor is the device that changes the polarity of 12V to the winch to extend or retract-essentially a double throw double pole relay).
have a look to see if its coiled in twisted as you pull the belt out if the buckledoesn't line straight to the female end well its probelyretracted in twisted to repair pull the belt out all the way and then realign the belt its quite hard to do so take your time hope this helps.
front calipers pistons straight in with c-clamp or piston retracting tool
rear calipers piston may need turning to retract should be provision
in piston face to install tool needed to performed work
tool is small square box with multi face that will service most calipers
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
First, NO, crossover cables are for connecting LIKE devices.. you need a Straight Thru cable for connecting 2 PCs to a switch.. So, if you are using Crossovers, then you are getting the correct results (cable unplugged). Replace with the proper cables, and it should see the network fine..
Also,
As this ProCurve HP 408 is 10/100 auto sensing, you should be able to automate speed and duplex within your NICs conifiguration...
Solution for Pioneer DV-C36 Multi Disk DVD player - tray door will not stay open.
My player would open the disk tray when the open button was press but when the tray was fully open it would retract back into the unit leaving no time to change or load disks. I found a poor connection at the ribbon cable connector was causing this problem. A seven conductor ribbon cable connects the main unit with the travelling tray. A position switch (S21) senses when the tray is fully extended and retracted. On my player pin 1 of the ribbon cable connector on the travelling tray was not making an electrical connection which causes the control system to retract the tray. The fault lies in the connector - the tang was not pressing against the ribbon cable conductor. I was able to desolder the connector and pull the contact out just far enough to reform the tang with fine needle nose pliers. This is very tedious and required an eye loupe for magnification. Tools required: #1 and #2 phillips screwdrivers Soldering and desoldering irons (or other desoldering tools) Fine needle nose pliers.
Remove the tray ribbon cable 1. Remove the cabinet cover - 6 screws. Open the tray. To keep the tray from retracting pull the power cord when the tray is extended. 2. Remove the front bezel from the tray. Gently pry up the bezel by relesing the catches with a small screwdriver. Allow the tray to retract. 3. Remove the front panel - undo large ribbon and wire connections on right, remove screws left and right, release two catch tangs on bottom edge using a small screwdriver on the inside of the unit. 4. Remove the white plastic cover over the laser mechanism ( 2 screws) Remove the disk carrier by removing the center screw. 5. Extend the tray again. When the tray is out the small ribbon cable is visible below the tray. Undo the ribon cable where it attaches to the main unit unit. 6. To slide the tray off the main unit use a small screwdriver to depress the stop catches (2) in the tray. They are molded into the tray. Pull the tray out further then lift up. 7. Flip over the tray and find the small circuit board the ribbon cable goes to. Desolder the motor wires (red and black) and remove the 2 screws holding the circuit board and position switch.
Use a multimeter to confirm there is an open or poor connection in the ribbon cable connector.
Remove the ribon cable and inspect the connector with an eye loupe or other magnification device. On my player contact #1 was not positioned properly to press against the ribbon cable conductor. You can either replace the connector or repair it. Warning: repairing the connector may damage it. To repair the contact desolder the connector from the circuit board. Bend the circuit board prong straight and push it into the body of the connector which will extend the contact out and the contact can be reformed. Be very gentle. Bending the contact may cause it to break.
Reassembly is the reverse. Don't forget to solder the motor wires with the proper polarity. Red and Black are labeled on the circuit board.
