Question about IBM NetVista M41 PC Desktop
How can i tell what model of computer? on a non running system.
  • jmb50 Jan 11, 2009
    How can I tell what model computer I have while its up and running..?
    Dos command..???
    Problem Solver:
  • 10 Answers
Hi, usually pc's has stickers on it, either on the tower or on the monitor, u could actually for the sticker first....opening tower is actually not recommended unless assisted by a tech besides yoll just get hardware info by doing that....to know the software i suggest just look for the stickers on the tower, hope you'd find out soon
Posted on Nov 28, 2007
SOURCE:
I need drivers for smart label printer pro
It would help if you had mentioned the Operating system and model number
The official Seiko site is:
Software Driver Downloads
However, Seiko has deleted its legacy printer support so you may have to find your drivers on a third party site
SLP Related Drivers
SII Printers Drivers Download for Windows 7 8 XP Vista
Note: With Seiko Smart Label printers make sure your printer is not connected to your computer until the Seiko software tells you to.
Important tips when finding and downloading application/ driver software from non-OEM sites
1. Never install any application from a non-OEM site that says it will scan your computer to determine what files you need. - search using the manufacturer name, model number, and current operating system on the computer you want to install the device on.
2. Only install the files you found. Never download any software suggested.
3. When installing the downloaded files, always select Custom Installation to make sure you only install the software you need. In this case only the application and driver files, nothing else ( no driver updating, security scanning, toolbar, etc. programs).
May 13, 2014 | Seiko Smart Label Printer Pro Thermal
Apple ios 6 download
- depends on the model of your iPad:
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer.
- but this model supports only iOS 5 - NO iOS 6/7/8
for all other models:
There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
apple-ios-6-download-zqolyaycyhlhw3jfhb4adlfm-5-0.jpg apple-ios-6-download-zqolyaycyhlhw3jfhb4adlfm-5-2.jpg apple-ios-6-download-zqolyaycyhlhw3jfhb4adlfm-5-5.jpg
Feb 25, 2014 | Cell Phones
Non-System Disk or disk error
Typically this is a sign of a defective hard drive. Depending on the make and model of your computer, there may be some built in diagnostics that you can run, by entering the SETUP menu when the computer first turns on.
You can, however, try restoring the computer back to the factory settings and see if that solves your issue.
Sep 06, 2011 | Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
What is the maximum memory for this computer?
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Computer Turns off
When you installed the Belkin, without running the install on your dad's
computer, Vista rebelled, and is now in a non-cooperative frame of mind
until or unless you obtain the cooperation and participation of your dad in the install process, so that his system properly integrates into the larger
network you are setting up.
I repeat that which was implied.
Get your Dad's cooperation and participation FIRST!
Apr 18, 2009 | Belkin (F5D7231-4) Wireless Router
I password protected my bios and don't know how to know how to remove it so i was going to remove the cmos battery
Removing the battery will not make a difference, it wil remove the system clock but he bios runs on non-volatile memory (memory that runs without power so you will not lose the password. Due to security reasons and without legitamate proof, i cannot tell you how to remove the password as the computer may have been stolen. let me know if you have proof, and i will TRY to help you.
Apr 15, 2009 | Acer Computers & Internet
Memory
I would recommend going to www.crucial.com and run their scan. It will tell you what you have, what kind you need, and the max you can install.
And yes, it matters about ECC and Non-ECC. Your computer can not use both. Most are Non-ECC and the scan will tell you that too. It will also tell you if you need to install in matched pairs.
Feb 04, 2009 | Kingston flash memory card - 256 MB -...
Xp in hp dv 6907 tx
If the laptop came from HP with Vista as the OEM operating system then the BIOS has been programmed to accept that operating system and only that operating system...other than windows 7. I have been told though that if you have a non-oem hard drive and initialize it on another computer and install it, there may be a chance nthat it will take an XP disc that has been streamed with service pack 3.
Jan 24, 2009 | Dell 1390 (WPCB143GDW1390WPCB143G)...
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
IBM NetVista M41 PC Desktop Logo
2,860 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
