Question about SAMTRON 55V 15" CRT Monitor
Cable problem hi my monitor's 15 pin signal cable is destroyed so what can i do for active my moniotr ? use new cable or apply other cable b'coz the original cable is not available at anywhere
  • lsvk75 Apr 16, 2008
    my monitor 15 pin vga cable damaged I am to connect a connector I do not know how to connect it can you please assist me the color coding for the 15 pint connector
I checked your problem which you fasing. If you are not monitor specialist after than you should try one monitor specialist in local market. First you should say to engineer that mansion origional data cable in monitor.Engineer says that original data cable is not available in market.after than if engineer pressure to you regrading for 15 pin connenctor.than you should agree for 15 pin connector because if you are only one single user than this connector will carry for one year because this connector is temprary for some time.
Posted on Dec 17, 2007
Repair wire from signal cable is disconnected or broken (15 Pin D shape Connector)
Soldering usually. Some connnectors were prefabricated with rubber being injection moulded. Your best bet is to purchase a 15 pin D connector and change the old one by soldering.
Mar 19, 2014 | ViewSonic E70f 17" CRT Monitor
Signal vertical pin
You need to find an adapter of some kind..Search ebay and other sources for possible cable adapters.
Nov 07, 2013 | Packard Bell FT500 15" LCD Monitor
What cord do I need to connect my 1810 gateway monitor to my tower
Your either going to need VGA or DVI. You need to check the back of your computer and monitor to see which type of connection you have. Then plug in the appropriate cable.
Pic of VGA cable: http://www.ccrzone.com/attachments/Image/VGA_M-M_6_.jpg
Pic of DVI cable: http://farm4.static.flickr.com/3216/2995518986_9deb622bff_o.jpg
Jul 19, 2011 | Gateway FPD1810 18.1" LCD Monitor
Cannot read the model number (chinese) I known i have a flat screen monitor 20 inches from DELL 2004 I want to connect it to my Inspiron 1100 .I need instructions this an handme down so I have no...
Since the cable you're describing is a VGA cable with the 3-row, 15-pin configuration, it will be the 1:D-sub selection. The DVI choice is for HD TV or a display card with HD capability. The S-Video is more commonly used for higher clarity video signals--less than HD of course, but approximately 15% to 20% sharper than a co-axial cable signal. (Reason: co-axial cable has all the color sigs squashed together while s-video splits them out into separate feeds.)
Sep 15, 2009 | Dell Computers & Internet
15''lcd monitor cable problem.
Hi, this may not be solution for what you ask but rong signal can or mayset u monitor on flames it hapined to me, why? hold on to old cable whan you can go and get new one, if you say you cant find, then get a moltetester chack the each ends pin to pin for contanuity. good luck
Jun 22, 2009 | Computers & Internet
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Mag monitor signal cable faulty
look into the 15 pin vga connecter care fully you will look numbers 1 to 15 which is very small it configration is as follows
1)red
2)green
3)blue
4)gnd
5)gnd
6)r return
7)g return
8)b return
9)5v from vga card
10)stand by
11)sync gnd
12)Sda(serial data)
13)Hsync
14)Vsync
15)Scl(serial clock)
at another end same letters will see take continuty and join new cable
Nov 10, 2008 | Mag Innovision InnoVision 996PF (White) 19...
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
Monitor
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
75 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
