Question about Acer Aspire 3000 Notebook
No power will not turn on
I was using it and it just turned off and will not power back up.I have tired everything I can think off.It was working fine with no trouble till then-Any help greatly appreciated-Robie
  • 1 more comment
  • Martel Arriesgado Nov 28, 2007
    Sir;
    My suggestions first is to check the power supply/cord and second the battery attached and the push button of the PC Notebook but if these three are good the next trouble is the main IC of the PC the processor. I hope you get it. thanks
  • rprater1968 Nov 28, 2007
    Marvin
    I had already checked the first two: Battery and Power Supply. How do I go about checking power button? Is the main IC the processor and how hard is it to replace? I cannot find a manuel for this machine.Thanks Robie
  • PFindley Apr 24, 2008
    I have a desktop and the same thing happened. I was using it and it just shut down on me and will not power back up. I have checked and it has power. Please help.
THROW IT ON HIGH WAY
Posted on Nov 28, 2007
TRXXAS WILL TURN RIGHT BUT NOT LEFT
is the steering servo working ? if so you have to set it back to the center then re attach the steering rod. turn the power off to everything and disconnect everything thats connected to the steering servo. then turn your remote on and set the steering trim on the remote back to center, then turn the power on to your car. the servo will automatically set itself to the center position, and then reattach the steering rods to your servo. make sure your tires are pointing straight forward as well when you screw the stuff back onto the servo. should do it. if the servo isnt working just replace it.
Nov 30, 2014 | Traxxas Slash
Are there any other booster pumps that I can use to run my pool cleaner? I had a Polaris bp4-60 for 7 years, it finally failed. Replaced it with same model. Ran for few mins then shuts off then restarts....
I think Polaris should refund the purchase price on these pumps. I changed the breaker, the whip, and upgraded the outlet (using 110). The dealer exchanged it for me, but would not give me a refund, and I had the same issue with the second motor. I used a Hayward 6060 pump as a replacement. Everything works fine.
Jul 04, 2014 | Polaris Pb4 - 60 Booster Pump
Hivi have a 2001 dodge ram pick up 2wd my back tires wont turn to go in reverse at all now to remind you in mi its been two or thre degrees below outside I was wondering what could be my problem I drove it...
Anything is possible in cold weather. BY driving earlier the transmission oil would have warmed up so the reverse should have worked. I'm thinking that may be from applying the park brake that the brakes are frozen to the drum/disc from the water / snow
Jan 06, 2014 | Cars & Trucks
Sony vpl cs5 projector will not turn on now power what so ever... Fuse on main power board is fine and power is getting to the main board at the back of the projector (the board which runs the bulb) the...
Have you tried the following:
Connect the power cord and turn the projector to standby mode.
Press the following keys on the remote commander in the following order for
less than five seconds each: RESET, <,>, ENTER.
Feb 26, 2011 | Sony VPL CS5 Multimedia Projector
My philips televison doesnt turn on Previously I would just unplug it and plug it back on and would turn on I believe that its the on/off switch that isnt working properly. The TV works it just cant be...
try this before you toss it...recently my magnavox 37" had been takign upwards to an hour to turn on. this past tuesday i check these threads to determine the problem. like many have said, its probably the capacitor, which it was n my case. basically i took everything apart and the bad (2) capacitors were obvious. one was oozing the electrolytic fluid and the top of the other started to 'dome' on the cap. i then went to a local electronics store (not radio shack, parts are too specific)... $3 for the (2) capacitors and a $20 solder iron. then you just de-solder the bad caps' and replace. i took the approach that - "what's the worse that could happen, the tv already didnt work?" well i just completed teh fix, it took about 3 hours and saved me nearly $300 that i didn't have. you can't be without your flatscreen at the beginning of football season!!!
gook luck
Sep 06, 2009 | Philips Magnavox 27MS343S 27" TV
Car died Ran fine, just quit.
I had similar issues with mine and it was the alternator. Replaced and everything worked fine. I think anytime the car loses power ie. disconnect battery. If you choose to change the alternator yourself its not easy. Ive become quite skilled at it. Easiest way is to remove front passenger tire. I know it sounds weird but that is the easiest way to get to it. Unless you are more skilled than I once you have the alternator removed you MUST remove the swingarm to get it out.
Aug 08, 2009 | 2002 Mercury Cougar
4wd won't work axles turn electronic box engages front tires won't lock in
have you checked to ensure that the actuator is working? if the actuator isn't working then the ring gear wont engage and won't turn the front shafts. try turning your key to accessory and put the truck in 4wd
May 23, 2009 | 1993 Ford Bronco
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Problem with my MX Gt 88!!
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
Nov 02, 2007 | JVC MX-GT88 CD Shelf System
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
