Question about HP Compaq Business Notebook NX9010
Compaq Business Notebook NX9010 runs on battery only???
I have a NX9010 Compaq Business Notebook and just recently after a little spill from a soda will not run from AC adapter. I shut off immediatley, unplugged and allowed it to dry. Then dismantled it and to my suprise was very clean still. Powered up and shut off in 20 seconds. Battery was bad and replaced and it works fine but will only run on battery. So here it is: (1) runs on battery. (2) Charges normally. (3) Will Not run on AC power. (4) It used to run both ways before. Any help greatly appreciated.
    Master:
  • 788 Answers
If it charges the battery but won't run on AC (without a battery) then something on the motherboard is probably faulty.
Posted on Jan 11, 2008
SOURCE:
Audio not working at all
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jan 23, 2013 | HP Compaq Business Notebook NX9010
How to dismantle hp nx9010
No problem, rigidarmz!
HP Support > HP Compaq Business NX9010 Notebook PC > Main Support page,
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=321850&lang=en&cc=us
Go down to the subheading -
Resources for HP Compaq nx9010 Notebook PC
Click on Manuals under this subheading.
Scroll down to the black bold subheading -
Service and maintenance information
Click on the file name -
Service Manual
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up.
(10 seconds just now using a medium speed DSL connection)
May I ask; anything I can help with?
Post in a Comment.
Regards,
joecoolvette
Oct 14, 2012 | HP Compaq Business Notebook NX9010
My hp compaq nx9010 wont power up. dc supply is good and the batteries are ok. No led light...
This is a typical symptom of motherboard failure. Your laptop's motherboard will need to either be serviced or replaced.
Feb 16, 2010 | HP Compaq Business Notebook NX9010
June 22, 2009 Dear Person, I have an HP-Compaq laptop computer, business model nx9010, s/n CNF3520KL4, with a failed hard drive. I am unable to remove the drive. I have removed the three (3) visible screws...
http://www.karlin.mff.cuni.cz/~motl/hp-keyboard/manual4700.pdf
PAGE 39
1. Unplug the AC adapter, if present, and then remove the battery.
2. On the bottom of the notebook, remove the hard disk drive rubber screw plugs and
M2.5×6.0mm screws. (The number of plugs and screws varies by model).
3. Carefully pull the hard disk drive out of the notebook.
4. Remove the four M3.0×4.0mm screws from the hard disk drive and hard disk drive tray,
and then lift the drive out of the tray.
5. Remove the connector bar from the hard disk drive.
The manual does have little picture to help you. The link above is to download the service manual.
Jun 23, 2009 | HP Compaq Business Notebook NX9010
Monitar drivers
Here is general download page for your laptop, you will also need to install network driver and audio drivers :
HP Compaq nx9010 Notebook PC - Download drivers
here is video driver :
» Driver - Graphics » Driver - Graphics - Intel
Try both, as 9010 is built in two different versions.
Please vote the solution.
Many thanks.
Aug 15, 2008 | HP Compaq Business Notebook NX9010
Drivelock code for hp nx9010
That is a hard drive password. You'll have to buy a new hard drive.
Jun 10, 2008 | HP Compaq Business Notebook NX9010
HP Nx9010
Is it completely dead?
Jan 25, 2008 | HP Compaq Business Notebook NX9010
Compaq nx9010 powers down to stanby.
select control panel off computer menu then select performance and maintence icon then select power options then you will see power options properties options tabs.. set properties to suit your needs
this should solve your problem
Jan 12, 2008 | HP Compaq Business Notebook NX9010
1024mb Ram for compaq nx9010
Yes. Max is 1 GB PC 2100 DDR 266 or higher
I have this notebook, and I got my memory at www.crucial.com
Nov 20, 2007 | HP Compaq Business Notebook NX9010
HP Compaq Business Notebook NX9010 Logo
128 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
