Question about Palm Treo 755p Smartphone
PHONE TRIPPING MY PHONE WON'T LET ME DIAL OUT...IT DOESN'T EVEN SHOW THE DIAL PAD...A DAY AGO IT SAID IT HAD LOW MEMORRY...PLEASE HELP ASAP
  • 32 Answers
You may have to clear out some memory by deleting some programs or files. Once your memory fills some functionality has to stop working. If you still want to use more memory you might consider buying a MicroSD card for expansion.
Posted on Dec 02, 2007
SOURCE:
I changed my password and it doesn't show anything
Hello My Dear:::::
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 04, 2013 | Cell Phones
Sometimes my dial pad doesn't work can't end calls
If you have memory card into your phone remove then try if it work,insert low memory....touch problem so,go cervicing center.
Nov 08, 2011 | HTC Cell Phones
I want to change my nokia 2690's internet connection
Good day. Erase the configuration settings and Reinstall the new configuration settings, then try to run the newly install setting for testing purposes.Seek a strong signal from your network provider to get fast connection. Or call your network provider operator then ask for configuration settings for your phone unit, I'm sure they will send you the configuration settings for free thru text message. Save as default to your phone then try to run. Thanks
Sep 11, 2011 | Nokia 2690 Cell Phone
I am using nokia 6300 but i have a problem about one wee ago when i started my cam its show that cam is on standby and i am unabel to capture a picture
Please check if the memorry is full in you phone if so copy save and make space.
If the fault is still present then a software issue might be the reason for the camera to click on.
check this out,
Aug 25, 2010 | Nokia 6300 Cellular Phone
Phone doens't turn on : (
hi. i would seriously return this phone asap. this phone has a defective circuit board and battery bay. the core has failed prematurely. return for a free replacement asap.
May 23, 2009 | i-mate Jama 101 Smartphone
How to set the time on our phone
Follow the instructions listed below. You shouldn't have any problems
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date
Mar 13, 2009 | Nortel T7316E 2-Line Corded Phone
How to change time on my T7316E Nortel phone
Step 1
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 11, 2009 | Lands Phones
How to unlock samsung x830 to use any sim ????????
you mght have to ring the phone company and pay a little extra, thsi is the main way and have never heard any other way of doing it, unless theres a new trick, if there is let me know. thankx
Oct 25, 2008 | Samsung SGH-X830 Cellular Phone
China Mobile N73 LOW SIGNAL PROBLEM
Hi there, I have been getting low signal problem.. also when i speaking with my friends its got call ends itself. And more often its shows "Emergency". Could u please Help me ASAP
Oct 23, 2008 | Sony Ericsson Mobile Bluetooth Car Kit...
Palm Treo 755p Smartphone Logo
655 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
