Question about Olympus DS-4000 Digital Voice Recorder
Read Only ?
I have a DS-4000. It is showing a lock symbol on the screen below the folder name. I have searched and figured out how I should be able to turn that off, but when i try it says it is "read only". it also says that when i try and record dictation. I have even tried connecting it to my computer and formatting it but it will not work
please help
  • minalth Feb 18, 2008
    this is on the recorder it's self, Can't work out how to turn the lock off. I can find it in the menu but no button seems to toggle between on or off it just keeps telling me that the lock is on...
I just installed AS and DS-4000 units. I upload my dictation to the server and it is then downloaded to my secretary. She couldn't change the folder because it was read only. I went on the server and changed the upload folder to full access and that fixed it.
I don't know if this is your problem. You might want to right click on the folder and see what the attributes look like under properties.
Posted on Nov 30, 2007
Cannot figure out how to get the convertible top to lock open, the little symbol won't go off and buzzes because the symbol still showing instead of the temp. It closes and locks just fine. I've gotten it...
Here you have not mention your car's name, but don't worry visit to the link given below, they have repair manuals, I'm sure you will get the solution to your problem Best Manuals
Oct 13, 2017 | Cars & Trucks
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Iomega 1tb drive have files hidden
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
I have an olympus ds 4000 and the folders are locked. How do I unlock the folders and what causes this problem? thanks, Sherise
Hello 1 Press the Menu button the menu appears 2 Press FF or Rew button until "lock"in sub menu flases on the Display. 3 Press Menu button the file locking set up process begins. 4 Press the FF or REW button to chose between "ON" and "OFF" ON: Locks the file and prevents from being edit or erased. OFF: unlocks the file and alows to be edit or erase 5 press the Menu button to select the option. Press and hold the MENU button for 1 second or longer to close the Menu.
Nov 24, 2010 | Olympus DS-4000 Digital Voice Recorder
My ipod nano 3gen 8gb is on screenlock and is asking for a code to unlock I have not put a code on my ipod before. Can you help me unlock my ipod without restoring and losing my songs.
Unlock Screen Lock and Volume Lock for Windows Vista
First you need to click on My Computer with your iPod connected.
The click on the iPod, click organized, select folder and search options, now click View the click to show hidden files and folders then click apply.
You should now see a folder named iPod_Control, click into this, then click device, now delete the file named: _locked to reset the screen lock and delete _volumelocked
Hope this helps
Dec 28, 2009 | Apple Audio Players & Recorders
How do I put the downloaded games in my Nintendo DSi's sd card?
ummmm u need to have an sd card this is a AAC
then put it in your dsi slot on the right then now read the steps
1.go to settings
2.go on data managemen
3.select sd card
4.click on your game
May 11, 2009 | Nintendo DS Lite Console
DS-4000 blue screens
may need to safely remove hardware before unplugging the devices
Feb 12, 2009 | Olympus DS-4000 Digital Voice Recorder
Locked file ?
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Locked file
Jun 18, 2008 | Olympus DS-4000 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
Had same problem. Found online handbook for DS-4000 and page 37 pointed way.
Press menu button on the handset.Go to sub menu. Page 37 of online handbook suggests you can lock and unlock from this but I used the format icon on the submenu to reformat the card. Seems to be working fine now.
Feb 14, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DS-4000 Digital Voice Recorder Logo
402 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
