I changed the filter, and called Whirpool, but can't get the light to go from red to green. I don't have a 'RESET FILTER' button. I'm seeing suggestions to hit the refrigerator light button 5 times in 10 seconds. That didn't do it. I tried 10 times as Whirpool suggested, still got red lights. Whirpool also said I could try to re-install the filter, or maybe the filter itself was bad. But I don't believe the filter system, and the light system are connected. So my red and green light don't have any idea what kind of filter I have in my refrigerator.
Any other ideas what I may try to reset my red filter indicator lights to green? Thank you.
Comments:
Aug 09, 2009
- My refrig does not have a single filter lite. On the freezer door, above the buttons for ice, water, and light, are 3 pairs of green and red indicator lights. The only button inside the unit is the one for the door to shut off the light inside. Right now the red are lit up. I'm trying to reset so the green are. Thanks for the suggestion though.
Try holding both buttons on either side of the filter lite in until lite goes off . May be the answer . If not off in about 15 seconds , wrong answer .
Comments:
Aug 10, 2009
- What is the complete model number ?
Aug 10, 2009
- OK ,an ED5 ***** has a filter reset button that you push 5 times in 10 seconds to reset lite . It is located on the control panel in the ref section . An ED2 **** has no filter reset . The controls on the dispensor of both , are mechanical . This means , if you choose a different setting , internally , a slide will move causing the red MARK to slide to a different position , therefore , marking a different choice . This same switch is on the ED5 and ED2 . The red is only a mark and not a light .
Hello, i Got a Problem with my S2OD RBB32-A/G Whirlpool Ref. its has a Fast and Random Clicking on...
(More)
Hello, i Got a Problem with my S2OD RBB32-A/G Whirlpool Ref. its has a Fast and Random Clicking on the Back in its Motherboard, i Open the main Board and it seems that its a Relay Who is Going Crazy! it started to happen for 5 min then last couple of month then its now lasting for 2 and 3 hours!! after this it t works normal, then when the Electricity goes off than On again the Hole cycle accrue over and over Any Help?
Hi, I have a Whirlpool S20DRSS33 Fridge Frezzer which has been making a chattering noise for a while...
(More)
Hi, I have a Whirlpool S20DRSS33 Fridge Frezzer which has been making a chattering noise for a while and now all of a suddern it has decided to deforsted the frezzer. Any Ideas what it could be?
Regularly the fridge alarm will sound and the letter d appears in the fridge side temperature...
(More)
Regularly the fridge alarm will sound and the letter d appears in the fridge side temperature display area. I mute the alarm and after 10-15 minutes the display returns to the set temperature.
unit is only 4 years old. paid 160.00 to replace compressor relay.made 2 batches of ice and stopped....
(More)
unit is only 4 years old. paid 160.00 to replace compressor relay.made 2 batches of ice and stopped. whirlpool gold gs6shexnsoo
