Question about LG DLE2514 Electric Dryer
WILL NOT POWER UP
THE UNIT IS GETTING POWER AS THE LIGHT IS ON BUT WILL NOT POWER ON. CHECKED THE BREAKERS AND ALL OK. I THINK IT MAY BE A THERMAL FUSE BUT LOOKING INSIDE IT LOOKS LIKE THERE MAY BE 3 FUSES. HOW DO I KNOW WHICH ONE IS BAD AND WHICH ONE IS THE THERMAL FUSE.
THANKS
  • Anonymous Dec 15, 2008
    I have the same identical problem. Will the a bad thermal fuse keep the unit from powering up?
  • 489 Answers
You have an issue with the control board and it will need to be addressed by a qualified LG technician.
Posted on Apr 28, 2008
My thermostat says the heat is on and its set to auto but the furnace wont turn on we've reset circuit breakers turned the unit off and on checked the filter but it wont turn heat on.
Look for this. 24 volt transformer. Thermostat sends 24v to the unit in order to tell the unit to turn on. The transformer is probably bad or isnt getting power and the unit isn't getting the "turn on signal"
Get a test meter and touch the two screws. If it's not getting voltage, check the 120v wiring to it and make sure it's getting 120v. If it's getting 120v at the wiring but not 24v at the screws then the transformer is bad. Easy to change and common part. Home depot or Lowes for about $35
Oct 17, 2017 | Power Computers & Internet
My Kenmore Dryer just quit today. I have checked the breakers. They are ok.
Many possibilities. Door switch, start switch, timer, thermal fuse, motor, belt, or improper voltage I think mostly covers it.
Oct 12, 2017 | Kenmore Dryers
Amana dryer not heating, replaced Thermal Cut off, High limit thermostat and Thermal Fuse, and new breakers in fuse panel
Hello, Before you replaced all those parts did you check each with a multimeter by performing an ohms test or measuring for continuity? By doing this it would tell if any of the parts that you had replaced were at fault. You can also conduct the same test on the heater as well. when performing any ohms or continuity test make sure the unit is unplugged and that you also unplug the part as well from the wires that are connected to it. I await your reply if you have any other questions. Thank you
Rick
Dec 02, 2011 | Amana NED4500VQ Dryer
WHERE IS FUSES THAT WOULD PREVENT FROM GETTING HOT
If you have a voltmeter or friend with one, check for ~220 volts AC across the two slanted connections in the power socket for the dryer. If zero, check the house electrical panel for tripped breakers (dual unit) for the dryer. If they are ok, then you have tear down the dryer to get the drum out. Once the drum is out, you have access to the heating elements and a thermal fuse or switch.
Jul 18, 2009 | Dryers
Kenmore series 90 dryer will not start
http://www.pcappliancerepair.com/cgi...2519&brand=WPL depending on model it sounds as if it is the thermal fuse, the cabinet will have to be opened , some are in back...either way you must unplug the dryer Safety First.. :)
Feb 06, 2009 | Kenmore 73952 Gas Dryer
Sub-Zero 601R Electrical
have you checked the main power button on top of the unit, behind the grill?
Jan 02, 2009 | Sub-Zero 601R
BADGER GARBAGE DISPOSAL NO POWER
Have you checked the circuit breaker on the disposal itself? In the bottom there's a little button that resets the circuit breaker. press it in and see if that works. If the disposal is still jammed you should hear a hum.
Dec 28, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Philips freevents notebook non starter
ya bad mobo no greese left on cpu take aprt redo greese thermal paste on cpu ok blow it all out dust getting labtop cooling bad never set these on beds big no no on any labtop must be on hard serfice ok cheak heat sinks paste proably none left worn out gets to hot fails killled power chips in it sell it for parts on ebay
Jan 21, 2008 | Computers & Internet
Maytag pyeg4500 no power
The thermal cut-out is located on the right side of the heater unit.This will kill your power. Change the t-stat also and check that your vent system is clear.
Dec 09, 2007 | Maytag PYE2300AY Electric Dryer
LG DLE2514 Electric Dryer Logo
132 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
