Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
My tv has sound but no picture
The tv was fine and then one day the picture went out. does any body know what this can be or where I can start? thank you
  • 3 more comments
  • ByteSci Dec 24, 2007
    I was watching my TV this morning as I have for the past 3 years and when returning from a snack break found thet the picture on my TV was missing but the sound was fine. Have you found the solution to this problem? Thanks for any help you can give.
    ByteSci
  • ALLTech
    ALLTech Jan 12, 2008
    My Philips 60PP9202 TV was given to me by a friend and i was told it has the same problem (Sound but No Picture). But i also have another problem, in order for me to try and find a possible solution i need to know what size fuses (all of them) go in it. My friend took them out and lost them. Does anyone know what size fuses go where?
  • Misty rain Feb 13, 2008
    I bought this same TV two years ago and I have no picture, but sound. It appears to be a common problem with this brand. Maybe a recall is warrant. What do one do? of course the warranty is good for a year. Called the service center, after six calls no help. Can't load a 60 inch in the back seat. Help!
  • slsman2006 Dec 11, 2008
    Philips 60PP9202
  • qmanq Dec 18, 2008
    I have the same problem with sound and no video. It was working and all of sudden the video went blank. Where I can go get the the schematics but preferrably where can I ship the board to get it fixed?
  • Philips Master
  • 5,138 Answers
Open resistor, hori output transistor.
Posted on Feb 10, 2008
SOURCE:
Why is my TV picture dim
Hello David
It sounds that the back light inverter board, and back light CCFL lamps to your TV need to be checked. It will be best to contact any service technician, because to check its back light CCFL lamps, you must disassemble the display panel, a very skilled work indeed. If you are sound in electronics, you can check it. If you wish to know more http://electronicshelponline.blogspot.com/ check this link. It has details. Pull up older posts there by its left side bar, or see it in 'Timeslide' option.
Jun 18, 2013 | Sanyo Dp55441 TV
I have a Vizio 37" HDTV that recently started losing the picture. The sound has been on continually but the picture now flashes steadily but mostly remains black. It went out one day, came back afte
it sounds like a backlight issue. It could be as simple as a few bad caacitors. If you already replaced the set and you just want $$$ toss it on your local Craigslist as a parts/repair set. There's always TV shop owner and parts scavangers that will buy the set as is. Price wise, if the set is in good condition and come with remote, and pedestal, I would ask $60 as is but you may get more
Mar 25, 2013 | Vizio VW37L 37 in. LCD HDTV
My screen went blank but the sound works fine. We were watching TV when the screen went out. The sound stayed on. We still get sound but no picture. Is this worth fixing? If so what is the best way to go...
all in one day my screen started by showing a u look at top and bottom. all three colors kind of separated from each other and therefore made shadows on all the writing and double and triple vision on people and images. then it drawed in from sides and showed some black. then it popped in the back and no picture. the sound then came back on with no picture. so i shut it off and unplugged it. what do i have to get to fix this? thank you, Robert Hopkins
Jan 01, 2011 | Akai PT5598HD 55" Rear Projection...
Tv has power no picture or sound
this is a proper electronic part failure this will require to be fixed by a proper tv technician as no body can guess ..call a qualified professional and get it repaired .ram mistry EMAIL [email protected]
Apr 08, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
The sound went out while watching a program on the set.
It sounds like the IC that controls the sounds has gone. Once upon a time they used to start with the letters TDA and other sets of letters that would make them instantly recognizable but nowadays it could start with anything so unless you know what you are looking for call out a technician. Good luck.
Sep 28, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Working fine next day red light on solid
Shorted hori output transistor and bad 1200pf 2k volt capacitor.
Sep 15, 2007 | Sony KP-53V80 53" Rear Projection...
The lights on but no-one's home - no picture on TV
Sounds like you have a short somewhere, probably the Horizontal Output Transistor. If there is a fault the led you mentioned probably should be blinking. You probably are going to need a tech to look at this as it is a very complicated process of elimination.
Jun 19, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
374 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
