Cant get my tv out to work
Boot in safe mode. (press F8 during boot, just before windows starts loading). If the desktop is then displayed, the graphics card is still functional. I am not very familiar wih NVidia graphics drivers but you may want to check (after a normal reboot) in the NVidia control panel. FIrst try cloning the image (both screens get same picture and resolution) If that doesn't work, try lowering the resolution. When you have found a resolution where the tv does display a picture, extend your dektop to it, set your monitor back to its default resolution, and keep the tv at the resolution you've found works.
If nothing out of all this helps, I think you should try reconnecting (and replacing, if all else fails) the cable connecting PC and tv. If that doesn't solve the problem either, well..then I'm out of ideas. The only option left is that some hardware is broken, and I can't fix that from here.
What you could try is to reinstall your graphics driver, although that is not liely to help, since you've only installed it recently.
I hope this solves your problem,
Yannick.
