Question about HP DesignJet 110 Plus InkJet Printer
Paper picking problem
My printer suffer from picking the paper the first time , it only picks it and
aligns it the 2nd or 3rd time , then on the display the 4th row from the left
blinks and shows a spanner icon , could you please explain me this problem . I have not use the printer a lot , I run a small architectural office and have to perform printing for my plans often .
Thank You
Cas
    Problem Solver:
  • 16 Answers
Try to clean the paper pick-up using soft cloth and water clean the rolls serval times it will solve ur problem
Posted on Nov 28, 2007
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
My copier will not pull the paper through to make copies it seems to want to jam -up ,when the paper start through
There are a couple of possible issues here. First, if the unit isn't new, the paper pickup rollers may have picked up 'chaf' from grabbing paper which over time reduces the ability of the rollers to grab paper. The 2nd option is that if the copier is older, the pickup rollers have dried up which reduces their stickyness and ability to grab paper. The 3rd option is that if you live in a very humid climate, the paper may have absorbed humidity, which can keep it from curling in the correct direction as its being pulled through the printer/copier.
Jun 20, 2011 | Computers & Internet
It does not pick up paper to align the cartridges, not will it print anything.
This model has a fairly common problem with the paper feed. If it appears that it tries to pick up paper but fails, then most likely there is a broken part.
Parts are not available for HP ink printers.. it's probably time for a new printer.
Sep 20, 2010 | HP 7210 OfficeJet All-In-One Printer
Paper jam problem. the red light blinking. how can you solved the problem
First make sure that there is no paper left in the printer paper path. If there is DO NOT JUST YANK IT OUT. You could damage the printer. Remove it carefully. Some printers have levers that release the pressure on the paper so it can be easily removed.
Check the paper path and make sure there isn't a flag or sensor out of alignment.
Power down, wait 30 seconds, and power back up to see if it clears.
If it does not pick up the paper at all, it will give you a paper jam error. Your pick up roller is probably dirty or worn out. You can clean it with alcohol or depending on the printer, replace it.
Make sure the paper tray is set correctly. If you have a removable tray, the paper size could have slipped back to a longer paper that what is in there and this will cause the paper jam error as the pickup roller will not be able to pick up the paper.
Jul 13, 2010 | HP Office Equipment & Supplies
Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Nov 12, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Not Recognizing Paper/Paper Jams
its a hardware issue ..
try add some paper and arrange it properly on the tray and also try to check you paper pick sensor..try to resolder it..maybe it suffered loss connection..the sensor is located at the pick mechanism itself....
Good luck,..
May 19, 2009 | Lexmark X8350 All-In-One InkJet Printer
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
HP DesignJet 110 Plus InkJet Printer Logo
119 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
