Question about Sony KV-36XBR250 TV
Dead set. Horz. out blown all around. replaced Q502 (H. out - blew again, saw spark). Replaced C517 (2.2 uf/250v, per suggestion). Soldered pins of T504 per suggestions. Suspect flyback, no equipment to ring it. No blown fuses (that I can find, B+ ohms out to collector of Q502). Any thoughts?
  • TAG KVP Nov 28, 2007
    I appreciate someone responding so quickly. Not sure what "STR"? Do you mean "SCR"; Silicon Controlled Rectifier? Any idea of cost for flyback and "STR"? - Thanks!
Str-- must be the power supply regulator 130volt
Posted on Mar 02, 2008
    Problem Solver:
  • 11 Answers
Replace the flyback and the STR, and also the H- out transistor.
Posted on Nov 28, 2007
Fuse blows on Maytag A9800 Top Loader
Usually caused by a faulty door switch assembly.
Check to see if there are TWO switches being operated by the door, the smaller of the two often fails.
Oct 24, 2017 | Maytag Washing Machines
My LG refrigerator has a blown fuse on the circuit board. Is the fuse replaceable, it looks as though it is soldered to the board?
Yes. This fuse is replaceable, but, you will heed to De-solder the contacts, in order to remove the damaged fuse. this can be very challenging. If you are not an avid user of a soldering iron, i would just simply replace the board. If the soldering is not done correctly, this will cause the board to short, causing a spark.
I would , also, verify that the fuse is available for a non technician to purchase. Most vital components will not be available for purchase, if the purchaser is not a certified tech.
Oct 21, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
Fuse blew on power now stuck in Protection Mode
Sounds like the out put stage of the amp is shorting, They are either 4 large transistors attached to an aluminium plate (heatsink) or one large chip with heatsink. also sounds as the driver stage went too when you switched it on the second time. If you know nothing of electronics I suggest you take it to an audio repair shop, as it is cheaper to repair than replace high power amplifiers.
Mar 29, 2009 | Audio Players & Recorders
Logitech X-530 5.1 speaker set blows internal fuse
Thats because its a 5amp 250Volts. You must have an older model and the beefed up the fuse later in production. mine just blew, unsoldered and about to replace. It states LF.T5AL250V. Hope that helps everyone. Takes about ten minutes to unscrew a good 20 screws, most of them are bolts and have nuts on the back so be prepared to have a pair of pliers handy, takes a 5 dollar solder gun from walmart to heat up the solder in the two points that are holding the fuse, once solder turns to liquid pull one side out, do the same to the other side to free the fuse. Fuse is in some kind of hold that i nearly impossible to remove (if you removed it then your in good shape, replace and solder in again) if you didnt remove it then head to home depot and pick up a small fuse holder and solder the leads in with just cheap solder from walmart. Be sure not to drip any solder over anything else on the board. Overall pretty easy fix.
Mar 23, 2009 | Logitech X-530 Computer Speakers
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Dvd player
i can tell you somthing that i used to do temporaly, take a couple strands from a wire any kind dosnt matter, like an old extention cord or sumtin, take like three strands 4 bigger gage an rap it around the fuse prongs an it will reconect the pos to the neg it works ive done it with a high powered stereo.
but make sure its unpluged... hope it works
Oct 01, 2008 | Memorex MVD2042 DVD Player
Blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:billyjones@fletchersite.com
Jan 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV not working
This is not an easy fix for most people! I suspect the ps is blown, R607, Q601,Q602 (use all org Sony parts, lots of factory 2nds around). This stuff blows to protect the fuse!!!!! Very rarely the input bridge rectifier or filter cap short.
Check R622, if open or discolored also replace VDR601(doesn't go bad very often). Check Horz output Q502. Inspect whole board for any bad connections, all parts with heat sinks(regulator ICs). Horz driver transformer, 0.47uf to horz driver tr. There could be other parts bad (flyback??). Make sure no supplies are shorted, check audio output supply, vert output supply, etc. Easily $150 repair at a shop. Good luck!
Oct 27, 2007 | Sony KV-32S36 32" TV
HAier HVT12ABS wont turn on
I had the same problem. My 18-month old Haier HVT 12A wine cooler stopped working. I unplugged the unit, opened the back, and saw the circuit board and the two fuses soldered to the circuit board. The top fuse was OK. The bottom fuse, labelled FUSE2 5A/250V on the circuit board, was blown.
I went to Radio Shack and purchased a spring-loaded push and twist fuse holder ($3) and a bag of fuses (another $3). I soldered the leads from the fuse holder to the top and bottom of the dead fuse 2, inserted a new fuse, plugged it in, and it has been working fine ever since (1 month). If the new fuse fails, it is easy to replace. Total cost $6.
Oct 10, 2007 | Haier HVT12ABS Compact Wine Cooler
Sony KV-36XBR250 TV Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
