Question about Toshiba Satellite A135-S2276 Notebook
Toshiba A135 S 4527 ......some times freezes
Hello friends....i have a toshiba A 135 S 4527 ...its causing problem from some days....it stops ,freezes during function,,,again it continue working ...after a while,,,,i noticed when cooling fan stops,,,,then it happens......here in Haiti ..no service centre of toshiba.....please help me to rectify this problem by my own
  • Anonymous Feb 14, 2008
    this is both an solution, and similar issue. you need to take/send the system to toshiba AS SOON AS POSSIBLE. there are a large number of these systems that shipped with BAD system boards, and they're back ordered, trying to get them fixed.
  • guiledazimba Mar 18, 2008
    My Toshiba A135 S4527 freezes when i realize an upload (only with Realtek).
    If i share a folder and move a file to other computer in the network it freeze!!!
    This is a system board problem?!
    Toshiba know this problem?!
    Tanks
I have only a question can i put a 2G memory to my toshiba satellite A 135 S4527
Posted on Mar 09, 2008
  • 383 Answers
Virus information and help Below is a listing of some of the different properties a computer virus is ... Alter the system time / date. Cause system to hang or freeze randomly.
Computer questions and answers listing 700 - 800 CH000700, What should I do when a computer freezes?
Good Luck, Please dont for get to Vote, Thank You
Posted on Dec 19, 2007
SOURCE:
Keyboard Freezed
Dear Friend .
you can use a usb keyboard or virtual key if you are not comfortable to so go to service center for replace the faulty keyboard.
Apr 02, 2014 | Toshiba Satellite C655-S5049 Notebook
Hello, my frig gets real cold but one day compressor stopped frozen stuff started melting. unplug plugged in few hours later it works for a week off again cycle continues for a few weeks. I replaced the...
0ba250e7-c31b-40ec-b003-ff0da31d62e4.jpgThis could be caused by a couple of things. If the condenser fan is defective and stopping while you don't see the fan stop it will cause the compressor to overheat and stop. The other possibility is a defective=> 12784415 Main Control Board or JAZZ Board A defective relay on this board will cause the same symptoms, Sea Breeze
I am here if you have questions...JT
Sep 21, 2013 | Maytag Refrigerators
Why do i have an intermittent problem with my laptop freezing up during startup? startup?
You may have a bug. You may start by going to control panel and see how many programs are trying to start up at the same time. When my laptop does that I normally go to the control panel and stop programs and keep them from turning on at start up. you really dont need all programs to start up at the same time. This may cause freezing and longer times to start at start up.
Dec 31, 2011 | Toshiba Satellite A665-S6086 Laptop
My laptop is gliching really bad and freezing it and stopping it then i have to strat over and it will do it all over again so what i want to do is reformat my toshiba laptop it is a 16" penteom duel core...
Hello.
Before formatting your operating system, check your memory. Remove all modules and add one at a time to test to see if problem memory is causing the freezing.
Also, download and install some free software such as Malwarebytes (anti-malware) or Comodo.(anti-virus).
Hope this helps.
Jun 25, 2010 | Toshiba Computers & Internet
Rotating the volume wheel on my laptop freezes Windows
My toshiba satellite l300-1aq laptop is freezing within a minute of start up? How can I root cause the issue?
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba satelite 135 I do not know the bios password
you'll find two solutions here that seems to work on some Toshiba Satellite models.
Jan 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba A- 135 - Jammed
My a135 would not boot at all, Removed drive, ram, wifi card, and it at least had some video.
Put the ram back in, and it actually tried to boot, put the drive in, andforced it to boot normal (menu gives a choice) and works great.
Then, I updated the bios. They have 7 revisions to the bios for that machine.
Dec 20, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Cooling fan stop working
It's normal for the fan to stop and start, as needed. However, it sounds as if the heat sink attached to the processor and fan may be clogged with dust/fuzz/hair, etc. If you can, vacuum or blow air back through the ventilation ports to clear the debris.
This usually causes the fan to run constantly. It's possible that you need to adjust the power management settings in control panel-toshiba power management.
Also,try keeping the laptop in a cool place and see if it makes a difference.
Let me know how it works.
Good luck
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
496 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
