Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Camera frozen, emits a buzz and "E18" in the lower left hand corner
I was trying to plug my s410 camera into the computer but I may have stuck the connecting cord into the computer hard drive's wrong socket. The minute I plugged the other end of the cord into my camera, the camera started emitting a buzzing alarm, the shutter is frozen halfway out and I get an "E18" in the lower left hand corner of the window. What did I do wrong and how can I fix this? Thanks - Teresa
  • 1 more comment
  • vas7 Dec 25, 2007
    I have the same problem. It was working just fine (have had it for over 2 years, used it a lot) and suddenly when I tried to click a picture it froze with the lens open. Now it won't shut or do anything else. It buzzes and displays E18 in the lower left hand corner.
  • Hyden Banda Feb 29, 2008
    The camera was working okay. Took some pictures. Then it starting giving problems of "freezing" which I would round by switching it off and then on. This time it just hang and gives a buzz sound when switched on, a few seconds later it gives an E18 error message.
  • creepstarr Oct 09, 2008
    I have this same problem. The lens is stuck retracted, closed inside the camera. I start it in picture taking mode and it beeps three times, buzzes, and goes to e18. then it turns off. If I start it in picture review mode, it just says e18 and won't let me look at my pictures. I don't know why a lens error would have anything to do with reviewing pictures...
    Problem Solver:
  • 15 Answers
Assuming you have tried the repair people on this site first, and need to follow it up further, I have found a site which gives some insight and proposes a fix if you would like to view it, it's at www.e18error.com They explain the problem like so:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
They also say how you may be able to fix it yourself - which is nice - well worth a visit! Hope this helps
Posted on Sep 02, 2008
SOURCE:
What does E18 mean on the screen of my camera?
E18 is a lens error. You might try this repair technique:
Canon E18 Error
Jun 04, 2015 | Canon PowerShot A20 Digital Camera
E18
The problem usually happens because dirt or sand get into the lens mechanism. To repair it, visit this link and follow all the steps.Rating the solution is highly appreciated..
May 25, 2010 | Canon PowerShot A75 Digital Camera
It says e18 on the screen
a chip on the boar has burnt out
Oct 18, 2009 | Canon PowerShot A80 Digital Camera
What does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Jul 10, 2009 | Canon PowerShot S50 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
E18 on Canon Powershot A95
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
E 18 problem
Your A410 problem really sounds like it might be a defective CCD imager. Canon would normally fix this for you for free, including free shipping both ways. http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Unfortunately this is only for applicable cameras A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
But you may want to contact canon anyways to see if they will help.
As for your SD500 e18 issue,
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 05, 2007 | Canon PowerShot A410 Digital Camera
Unusable
This is a hardware problem common with many Canon cameras. Unfortunately, there is no easy way to fix this. Canon can fix it for you, but they charge more to fix it than it would probably cost to replace the camera. There are entire sites dedicated to those who've had this error, but there is no way to fix it short of sending it in to Canon. One such site is here: http://e18.bitnet.cx/comments.php
Aug 28, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
