Question about HP LaserJet 2100 Printer
Need A Manual
I have a HP Laserjet 2100 Printer, Is there a place where I can down-load a manual for Free. Thank You, Shaye
  • 3 Answers
HP has a pdf manual online for your model.
Here is the URL link for the HP LaserJet 2100.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=25469
Posted on Nov 28, 2007
SOURCE:
Please sir, I need the service manual for hp laserjet 1300 printer
If you need service for your hp printer. you may visit HP Customer service or dial toll free number- 1-800-585-2494. hope this will help you better.
Jun 10, 2014 | HP LaserJet 1300 Printer
How to reset counter hp lasserjet C4096A toner
Its simple thing to reset your counter volume for ink or print setting values. As latest drivers installation will make to default values from their you can easily reset the values. download and install the latest drivers.
HP Laserjet 2100 Printer Driver Free Download For Windows
May 13, 2014 | HP LaserJet 2100 Printer
Where do I load the original to be copied on this printer. I don't have the manual.
Here's a few links that might help you with the printer in general.
The HP LaserJet 2400 Series Manual - This covers 2410/2420/2430 HP LaserJet Printers. I uploaded it to my dropbox and this is the shared link for the .pdf file.
HP Laserjet 2400 Series Software Manual - 2410/2420/2430 LaserJet Printers
Here's the HP2400 Series Software Manual - I've also uploaded this to my dropbox account.
HP LaserJet Printers - Steps to Print Manual Duplex Using the Application Settings or HP LaserJet Driver Settings
Aug 31, 2013 | HP LaserJet 2420 Printer
I got a new computer but an old printer and I need the driver for it. It's a Hp officejet 2100 tn. I worried I'm going to download the wrong one and get virus's.
All versions of windows since Win XP have had the driver for the Laserjet 2100 built in. When you connect your printer to the computer and reboot it should say 'found new hardware' and load the correct driver automatically.
Sep 23, 2011 | HP LaserJet 2100 Printer
Need A service Manual for H P 435
You can download here all the PDF manuals concerning the HP Color LaserJet CP2025 serie.
This serie of printer included the HP Color LaserJet CP2025DN Duplex Unit.
Hope this solution help you.
Please feel free to contact me if you have any other questions or comments about this solution.
Thank you!
Apr 12, 2011 | HEWLETT-PACKARD HEWLETT PACKARD HP COLOR...
I have a 2100 HP Laser Jet Printer with no manual. After it prints one doc. it continues to feed 1 1/2 sheets of paper and stops. The paper is hung in the printer and I have to take out the paper so I can...
this might be a hardware problem please follow the steps
1.disconnect the power cable from the back of the printer
2.press and hold the power button for 20-30 seconds
3.reconnect the power cable back to the printer
follow the instruction from the below mentioned URL
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=25469&prodTypeId=18972&prodSeriesId=25469&objectID=bpl06448
and if still its the same problem try and make a copy if the copy is not fine its surely a hardware problem contact HP if the printer is in warranty
hp toll free number -1800-474-6836.
hope your issue gets resolved
thank you
Hamid
Feb 19, 2010 | HP LaserJet 2100 Printer
Hp2100 laserjet printer producing very faint copy
Could be a few things. I would check the transfer roller first it is the roller that sits under the toner cart. This roll should be spring loaded. Press down on each end, it should move down and come back up. If someone removed this roll the springs may be missing or out of place.
Let me know if this helps
Mar 03, 2009 | HP LaserJet 2100 Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2100/TN
Replace toner cartridge drum/blade RS, slim faint outside chance it is a fuser (hot bit rear) problem, doubt feed issue
To confiirm to yourself it isn't a feed issue, try feeding A4 via manual bypass (envelope slot) and doing a print using manual bypass tray, just override size missmatch warning if it appears (tick i think when beeping). should do same fault as feeding via cassete
You can also print a test page from printer via operations panel to confirm it is printer problem not software.and you can do a paper path test from whatever feed slot
To eliminate it being fuser problem try printing and turning the power off when paper is 1/2 way threw print job, remove cartridge and exaimine unfused (still image rubs off) print, if image is fine then it is a fuser issue but be carefull to note how much of a page needs to be printed before image repeats so you know if it is right or wrong.
But thats just tecnical possibitys, Change cartridge should fix!
Odds are 95% cart 4% fuser 1% others i reckon!
Oct 19, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 2100 Printer Logo
151 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
