Question about Power Acoustik LT-980/2 Car Audio Amplifier
WIRING DIAGRAMS HOW TO PROPERLY WIRE THIS AMP
    Problem Solver:
  • 17 Answers
Go to rockfordfosgate.com
Posted on Dec 10, 2007
Use true 4 ga. for power and ground, 12 ga. remote turn on, use 12.ga. for subs lots of, air flow needed mount it snug.
Posted on Jun 19, 2009
185 5uo engine. Where can I get a wiring diagram?
Yamaha Motorcycle Manuals - ClassicCycles.org
www.classiccycles.org/1852/1936.html
Yamaha SR185 SR 185 Illustrated Online Parts Diagram Schematics HERE. YamahaSR250 SR 250 Electrical Wiring Diagram Schematic HERE. Yamaha ...
Yamaha wiring diagram scanlift sl 185 Questions & Answers ...
www.fixya.com > Forum > Tags > wiring diagram scanlift sl 185
...to highbeams and I want to wire them to lo-beams what wires go were THe Green wire is the low beam, to verify this google Yamaha 1100 wiring diagram and ...
KLF 185 & 220 Bayou Wiring Diagrams - YouTube
? 1:50
https://www.youtube.com/watch?v=QVnHR4je8yc
May 17, 2014 - Uploaded by Tufdog's Place
The Link I used to find these diagrams is below https://search.yahoo.com/search?ei=UT... My photos and ...
ServiceManuals - Motorcycle How to and Repair
www.thejunkmanadv.com/repair-and-service-manuals.html
Feb 09, 2016 | Yamaha Motorcycles
I'm not getting power to the starter on my 1999 dodge ram
Have to do some testing to find out why
I would assume you need a repair shop
If your going to work on your own vehicles,
you need reference material, in the form of factory
service manuals & in your case, wiring diagrams
If you do not have wiring diagrams & a volt meter
& basic electricity knowledge ,your not going to
even find a problem
Nov 13, 2014 | 1999 Dodge Ram
I order a new fuel pump on web it came with rectangle plug but my came with square one. I installed it the pump works good but the gauge doesn't. Wires are wrong.
All I can say--- is why would you install a pump
with the wrong wire connector & how,cut the
wires & soldering
Except for the wire colors
You can't use that one & expect to have
the factory designed results
IF-- you get wiring diagrams & remove the new
pump, you may find you still can use it
I do not work on any vehicle without first
having wiring diagrams,even if not needed
Aug 12, 2014 | Cars & Trucks
Harley wiring diagrams
Hi Anonymous, for a small fee ($5.50) you can download an entire service manual with wiring diagrams, please visit website below:
http://harley.manuals.cc/
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 03, 2014 | 2000 Harley Davidson FLHT Electra Glide...
1999 ranger wont start
If that was my vehicle I would not have changed one part
I would have gotten out my wiring diagrams & walked thru a
logical sequence of testing what I had & didn't have, as far
as crank sensor output,fuel pressure,injector pulse,etc
Seeing a how pcm's seldom fail ,your just throwing parts at it
& not testing a thing
You need the wiring diagrams to see & learn how the various
systems work
You can actually trigger injectors,coils,relays,etc if you can
use diagrams, test light,meter & jumper wires properly,otherwise
you need professional help
Jan 08, 2013 | 1999 Ford Ranger SuperCab
TR274 & TR 291 Wiring Diagrams
Copy following link for specific wiring diagrams for combo switches:
http://waterheatertimer.org/How-to-wire-switches.html#combo2
Combo switches require Neutral wire in the box.
Neutral wires are usually the white wires twisted together, covered with wire nut, and pushed to back of box.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 09, 2012 | Cooper Wiring Devices Triple Deco Single...
Staircase wiring circuit diagram for 2 way switch
Copy following link for wiring 3-way switches (where 2 switches control same lights)
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Each 3-way switch has 3 screws (plug green ground screw)
Two screws are 1 color usually brass, and other screw is different color usually dark.
The dark screw is common screw.
There are two basic wiring diagrams: Line-side/Load-side with neutral wire. And Line-side/Load-side without neutral wire.
Open link above and scroll down to see both wiring diagrams.
Nov 04, 2012 | Prime 10 Amp Circuit Breaker
Car audio wiring color codes.for 1988 ford f150 truck
Thanks for using FixYa.
1988 Ford F150 Truck Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Jan 25, 2011 | Car Audio & Video
Best Buy installed a new cd player in my 03 Tiburon GT. All of my instrument cluster lights no longer work. The fuse is ok. Anyone know the wiring color codes. Best Buy is unco-operative and want me to...
Is fuse 29 the one you say is good? If that fuse is good, check your tail lights. If the tail lights are not working either, check the TAIL LAMP fuse in the engine compartment relay box.
There are 2 different wiring diagrams depending on if you have the amplifier or not. If you have only the basic radio, it would not have the amp. If you have a premium option, it would have the amp.
There is also another wiring color code I got from another website that's different--more like the standard colors. I'm going to include that color code as well in case you find the colors don't match the diagrams.
In the diagrams, there are actually 2 wires that run the light on the radio. One is green and one is brown with a white stripe. An aftermarket CD player will probably not have any wires for the light and just have it come on when the radio is on--day or night. So, if they connected those factory wires anywhere, that may be your problem.
I have pasted all of the relevant wiring diagrams below, though they may be hard to read because of picture size policies at FixYa. Please let me know if you have more questions.
Possible alternate color scheme:
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
Nov 09, 2010 | 2003 Hyundai Tiburon
My amp i just instaled is a terminater mtx 250 watt amp and the lights are flashing instead of a constant red i checked my power and ground what else would it be
Check your remote wire on both the deck and amp... If the remote wire is loose it will turn the amp on and off constantly... Also check to make sure that the fuses on the amp it self are properly seated.
Oct 30, 2010 | MTX Car Audio & Video
Power Acoustik LT-980/2 Car Audio Amplifier Logo
460 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
