Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips Magnavox 9p6040 c102
Greetings!
The picture shrinks... the problem occured only when alot of white was projected. Obviously theres a power issue to the lamps. As the tv warms up, the problem goes away. Sounds like a failing capacitor, but i dont have schematics. Anyone know what cap to try?
P.S. I just realized i could try Freezing caps till a reaction occurs...
    Problem Solver:
  • 6 Answers
IC's on convergence bd. 1st try opto coupler philips part# 483520988561 actual part# to buy HCNW136 some replace all 3 IC's philips# 483520987834 actual# MC34065p and philips# 483520987712 actual# SC78104 search google to buy.Datasheets at datasheetcatolog.com
Posted on Dec 01, 2007
    Problem Solver:
No sound
Posted on Apr 20, 2011
  • Philips Master
  • 3,459 Answers
You can buy a repair kit and instructions here.
http://www.magnavoxhelp.com
Posted on Jun 21, 2008
SOURCE:
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture shrinks and expands
Not positive but this sounds like the impending failure of a specific power supply, namely an output providing deflection voltage to the CRTs. This may be simply a circuit on the main supply or could be a separate supply on a different board than the main supply.
If it is not affecting brightness and contrast, it isn't likely to be the primary supply that is failing. I'm pretty sure it will continue to degrade.
Oct 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 9P6040-C101-60" Rear Projection Television
You can get a repair kit for the shrinking/expanding on www.magnavoxhelp.com. This is a common problem with this model.
Sep 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 9p6040 c102
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 13, 2008 | Philips 9P6040C 60" Rear Projection...
9p6040 c102
Visit www.TvRepairKit.com for a repair kit. Its a common problem and an easy fix.
Jan 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
The picture is fuzzy and shaped like a hour glass
Dec 02, 2007 | Philips 9P6040C 60" Rear Projection...
9p6040 c102 60" television - has power, no sound or picture
Screen shrinks and expands and wams up after 10-20 minutes and then went out completely? Power light still comes on and remote still works? This is a common problem for this model and is most likely related to a bad chip. A tech will charge you over $300.00 to fix it but you can buy the repair kit including the chip, step by step instructions and repair manuals for under $40.00 if you are willing to do a little soldering. Go to http://www.magnavoxhelp.com/ and enter your model or chasis number and order the kit. This will not fix color problems!
Sep 20, 2006 | Philips 9P6040C 60" Rear Projection...
Phillips Magnavox 60" tv
If your video is shrinking and expanding its the opto IC. You can get a repair kit from www.magnavoxhelp.com
Sep 11, 2006 | Philips 9P6040C 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
593 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
