The player door will open and close, When I put a Cd in it will shuffle to the cd but will not even try to play it- even when repeatedly pressing play. Once it has tried the bay with the loaded cd it will again shuffle but will now only allow you to select the bays with out cds in them. It is like it knows there is a cd in a certain bay and does not want to try to read it and will not allow you to go to it. Any suggestions?
With this unit...you won't have easy access to optical lens because it is a multi disc front loader.When you load the cd...does it display numerical info or does it display all ZEROs.If it displays all ZEROs...pick up a wet/dry cd/dvd lens cleaning disc and use it as per the directions on the package.Most discs have music encoded on them...If this music plays...finish the cleaning process and then try to play your music cd's.If you still have problems after this..it is an issue that needs repair...I hope this was helpful...
Maybe you should try cleaning the lens by opening the shelf TOP, and cleaning the lens? I had that problem. Take a Q - Tip with alcohol on it and it will do the job. Careful to not touch any components, and unplug first! The system can electrocute you even if unplugged, so don't touch any electronic component else than the lens inside.
