Lexmark X4270 All-In-One InkJet Printer
Problem for Lexmark X4270 All-In-One InkJet Printer
Black ink
By mansternow2 on Nov 28, 2007
there is ink in the cartridge, but it is not coming out on the paper.
Same Problem
Dec 06, 2007
-   wont print black ink-   Guest
Solution #1
posted on Nov 28, 2007
Somewhat Helpful)
Parrotscage
Rank: Apprentice
Rating: 78%, 6 votes
It's been my experience when an inkjet printer produces unfavorable printing results ("scan lines or no color) the most common cause is clogged print nozzles. The most common cause of clogged print nozzles is lack of use and the ink dries and hardens in the nozzles.
Your particular model of Lexmark as well as other brands generally have a utility to assist in unclogging the jets by forcing ink through the nozzles. This does "waste" ink, but it is the "easiest" way to attempt in unclogging the nozzles.
For your model try the following: (This is an excerpt from the Lexmark site.)
  1. Load paper.
  2. Click Start Programs Lexmark 4200 Series Lexmark Solution Center.
  3. From the Maintenance tab, click Clean to fix horizontal streaks.
  4. Click Print. A nozzle page prints, forcing ink through the clogged nozzles to clean them.
  5. Print your document again to verify that your print quality has improved.
  6. If you are not satisfied with the print quality, continue with step 7 and then print your document again.
  7. Wipe the print cartridge nozzles and contacts:
  1. Remove the print cartridges.
  2. Dampen a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps c through d.
  6. Let the nozzles and contacts dry completely.
  7. Reinsert the print cartridges.
  8. Print your document again.
  9. If the print quality does not improve, repeat step 7 up to two more times.
  10. If print quality is still not satisfactory, replace the print cartridges.
Was this helpful?
Yes
No
Popular Solutions for Lexmark X4270 All-In-One
Questions and Unsolved Problems for Lexmark X4270 All-In-One
Do you recommend Lexmark X4270 All-In-One InkJet Printer?
Answer
Answer
I have a lexmark X4270 printer/fax machine. I replaced the black ink cartridge but the machine says... (More)
Answer
it says alignment page printing but to paper does not move
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Newport, KY
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
