Question about Samsung Yepp YP-T9 Digital Media Player
Re-Charging Ok, so I keep having the same problem when I try to recharge my mp3 player. When I plug it in, it says it is fully charged, when it is Not! I've tried the a/b + menu button at the same time but it doesn't work. I've had it replaced once already, and sent it and "fixed" another time. I really like my mp3 player, but I'm getting tired of sending it in all the time and never being able to use it!Can you help?
Is the battery youre tryin to charge a nuckel cadium if so it might be havin memory issue if you kn the model number of battery and or out put and voltage out put DAA-BA0004,
  • Output Voltage: 3.7 V
  • Capacity: 2000 mAh you can try goin here to oder a replacemnt http://stores.ebay.com/Battery-Boy
  • Posted on Nov 28, 2007
    Sro 8120 transonic mp3 keeps cutting out like its going flat when its charging a red light comes on sometimes flashes and the device will only play for a few minutes
    Taken from the Quickstart User Manual
    LED Light 1 (L1) - is by the earphone socket
    LED Light 2 (L2) - is by the USB connector
    Charging: Please switch on the player before charging. (Push the on/off switch to 'on' )
    When charging the battery for the first time it is recommended that the player is charged about 8 hours. Connect the player to an active USB port using the supplied cable. The computer must remain on during the charging process.
    Recharging: Recharge the player will take about 3 to 4 hours. When it's charging, L2 will turn on in red, when it's fully charged, L2 will turn to green light.
    When playing music, L1 will shine.
    Sep 01, 2011 | Audio Players & Recorders
    Recharging battery
    it doesnt need to be turn on while charging.. you can see an indicator stating the unit is charging when this indicator stops it means the mp3 is now fully charge..
    Sep 10, 2008 | Audio Players & Recorders
    Tip
    How do I charge my iPod touch for the First Time
    <p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
    on Aug 09, 2011 | Apple iPod touch
    Hello, I have a question: how many hours do i have to recharge my Philips GoGear SA018 mp3 player? In the guide its written to keep it for 3h and when the light is green it means its recharged,however...
    If its new and your having this problem DO NOT hesitate to take it back. However most new gadgets when charging for the first time may require a bit more charging time than stated in the manuals.
    If the problem persists take it back.
    Aug 12, 2010 | Philips GoGear Clip SA018102S/02 2 GB MP3...
    After charging my MP3 player it appears fully charged but it will only play for about an hour and the battery runs down. i have recharged it again, same thing. now what?
    The very first time you charge your battery YOU MUST CHARGE IT FULLY!!! If you didn't, that is probably the problem.
    Also, even if you charge the player for just a couple of minutes it will APPEAR to have a fully charged battery when it actually doesn't.
    Most portable media devices require at least 20 minutes to an hour to fully charge whether the screen shows that it is fully charged or not.
    Jun 30, 2010 | SanDisk Sansa e250 MP3 Player
    THE BATTERY DOESN'T RECHARGE.I USED TO KEEP THE PLAYER PLUGGED CONSTANTLY WHEN SWITCHING IT OFF SO THAT THE BATTERY WOULD NOT RUN OUT OF STEAM..
    by keeping the player constantly plugged in when of will have seriously shortened the battery life, rechargeable batteries ( exept the very latest ones) perform best by charging then using until fully discharged and charging again. this will ensure your battery lasts a long time, constantly charging a half charged battery will shorten the batteries life.
    Nov 23, 2009 | Audio Players & Recorders
    Zen V not charging, battery all out
    Try resetting the device and charging it again. You may have to charge it for a few hours though.
    Apr 14, 2009 | Creative Labs ZEN V Plus MP3 Player
    Zen Vision M battery not charging
    The problem was partially solved in that I put my old battery back in and at least it charged properly. I did receive a new battery from BatteryMill and I fitted it and left it charging for 5 hours. However, when I unplugged it to see if it had charged at all it did the low battery thing and then when I tried to recharge it the battery fully charged symbol ame up. I suspect that had I left the new battery charging for say 24 hours it might have charged fully. However, I have decided to send my batteries back and get a refund. The problem must be something to do with a battery memory problem.
    Jul 31, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Philips mp3 player sa6045
    This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
    The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
    These messages mean that the player does not need the "Safe to remove" procedure.
    It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
    Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
    Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
    Samsung Yepp YP-T9 Digital Media Player Logo
    Top Samsung Audio Players & Recorders Experts
    Electric Dime
    Electric Dime
    Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
